Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Battery Relocation questions
Old 08-09-2012, 03:34 PM
302 Z28's Avatar
302 Z28 302 Z28 is offline
The main (IMHO) reason to using a second solenoid in the trunk at the battery is to eliminate a hot + heavy gage wire running from the rear to the front of the vehicle. If that wire shorts you will more than likely loose your car to a fire.
Vince
