Battery sitting on concrete..is it bad? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-07-2005, 08:36 PM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
During a lunchtime discussion, the topic of car batteries sitting on concrete came up. I say it's a no-no. It wrecks the plates in the battery and they won't hold a charge after you sit them on it. A buddy says that that was only with the older batteries. He says now they use a thicker plastic on the base and they don't short out like that anymore. Who's wrong? I've got a soda riding on this...
In a while, Chet.
Old 07-07-2005, 09:12 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
no
There is a posting on here somewhere about this. It is fictional. Leaving a battery on cement is no different than leaving it on wood or rubber.
http://www.inct.net/~autotips/battmyth.htm
Old 07-07-2005, 09:32 PM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
[QUOTE=bracketeer]There is a posting on here somewhere about this. It is fictional. Leaving a battery on cement is no different than leaving it on wood or rubber.QUOTE]
I would agree with bracketeer, there is no difference what you set the battery on, besides what is in cement that could cause the problem. I think that battery technoligy has came a long way in the past 15+ years and they just last longer. I have heard my Dad say that setting the battery on the cement floor will kill it. Maybe back n the day when the life of a battery was short.
Old 07-07-2005, 09:38 PM
schnitz's Avatar
Wiki Edits: 54
So in other words, I'm out $.50.... Oh well.
In a while, Chet.
Old 07-07-2005, 09:48 PM
1931 steve's Avatar
Wiki Edits: 4
Thats one cheap soda!!!
Steve
Old 07-07-2005, 10:05 PM
aka Duke of URL
That was back in the days of tar top batteries. The last one I saw (I think) was the mid-sixties. Used to sit pennys on top so the acid would attack them instead of the car's sheet metal.
GAWD! I'm old...
Old 07-07-2005, 11:00 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
GAWD! I'm old...
So that's where the penny thing originated. I remember when I was a kid the neighbor always had his hood up working on his car. Every time I visited/aggravated him I left two cents richer.
Old 07-08-2005, 12:03 AM
aka Duke of URL
Hope you didn't put 'em in your pocket. That battery acid is some quick stuff on clothes...
REPRO BATTERIES-
Hard rubber raised letter case, POLY TAR** top with red Power Punch caps. 100% correct.
Old 07-08-2005, 07:52 PM
ComingApart's Avatar
I guess everybody has heard that line about not putting batteries on concrete, but nobody has ever given me a plausible explanation for how it could cause any damage.
On top of that, the owner of my local part store has most of his Delco brand batteries on his concrete floor and I've never had any problems with any of the multiple batteries I've bought from him.
I stopped giving that story credibility years ago.
Old 07-08-2005, 08:18 PM
the whole battery/concrete thing comes from way back when batteries had a wooden outer shell and a glass inner case to hold the acid. if you left the battery on the concrete , the moisture from the concrete would swell the wood. when the wood swelled , it would put pressure on the glass , possibly causing it to crack and leak acid. this , ofcourse would turn the battery to junk. it no longer applies to modern batteries.
Old 07-09-2005, 01:24 PM
E.T. divided by $ spent= Speed
I was allways told that putting batterys on concrete will kill them too.
Now my thinking is a battery costs $75+/- ,lifting it off the ground and putting it up on a shelf is free.So why not??
Car battery: $75
Lifting battery onto a shelf: 1min labor
Finding it dead on the concrete: Priceless
Theres somethings in life money can't buy,for a new car battery theres Discover.
Old 07-11-2005, 07:50 AM
docvette's Avatar
Wiki Edits: 12
Storing Battery's
Doc here,
Weather or not the battery goes dead on concrete is only a small issue...
The Best way to store a Battery, Is up on a shelf, in a plastic or rubberized tray...
Some of those reasons are, You can drop things like HEAVY auto parts on top of them just sitting on the floor..before you know it, you have a nice burned white trail down your floor and everything destroyed in it's wake..
Sealed battery's...aren't..they just have higher pressure filler caps UNDER an almost seamless top, and under extreme duress, can weep H2So4 all over...
Lets not for get dropping the errant 12 inch breaker bar..which according to Murphy will always land between the + and - posts...
And kids, can get to them which is not safe at all either...
It's always best to store these things up on a shelf, in a tray with a plastic or rubber mat, and the terminals insulated. Why invite trouble?
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
bad regulator, or bad alternator bildo95 Engine 4 01-24-2006 04:27 PM
alternator not charging battery again 73chevyhelp Electrical 2 10-18-2004 11:58 PM
starting issues...battery or starter? 79454 Engine 6 10-25-2003 04:10 PM
sucking battery juice FoxThunder 5.0 Electrical 9 08-30-2003 07:46 PM
Diagnosing Bad Catalytic Converter deleteall Engine 4 04-14-2003 04:43 PM
