Originally Posted by 67Mustang Al.
Just wondering if an auto spark could head me in the right direction for the correct AWG starter cable for a 347 equipped with a high torque starter. The cranking speed is producing a warm cable. The car came with 1/4 diameter cable or 6mm. Connections are all good with a high CCA battery. I am thinking a step up is required in diameter.
Any suggestions appreciated.
Al.
I agree get a bigger cable, and don;t forget the longer the cable is you should make it bigger. So if you have the battery in the engine compartment you do not need to go as big as if the battery was in the trunk. but you should go bigger. I always go 2/0 from either place but 1/0 won't hurt, that,s on standard starters.
Later 35terraplane
I also solder
