Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Battery went dead sitting, What to check?
Old 06-30-2011, 09:56 PM
evolvo's Avatar
evolvo evolvo is offline
OK, get one of these http://www.stu-offroad.com/electrica...t/tlight-1.jpg. Then disconnect the Negative battery cable from the - post. Connect the test light between the - cable clamp and the - battery post. Is the test light lit up? If it is you have a short/drain in your system, could be that instrument light, if it's really bright you have a big draw, not so bright just a little draw. Now start pulling fuses one at a time. When the light goes out you've found the short/drain. See what the fuse controls and start tracing out the wires in that circuit. Could be something as simple as the ciggy lighter stuck, I've been paid to fix that one (!) or something more complicated. Good Luck
