Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - BB Chevrolet Engines: Ideal Years/Applications For Cheap Drag Racing Swaps
Old 05-06-2011, 06:39 AM
cal1320's Avatar
cal1320 cal1320 is offline
A mild 454 with a 3 speed trans would be reliable and fun. Cast crank, 781 heads with 2.18/1.88 valves, around 9 or 9.5 to 1 compression(pump gas), RPM intake, 750/800 holley, 3500 stall, cam around 245 @ .050 and .570 lift will be easy on the valvetrain, rear gear depending on tire size
This should get you about 525hp at the wheels. Mid to high 11s and will last forever as long as you dont over rev it
