BB Mopar Head Choices - Hot Rod Forum : Hotrodders Bulletin Board
View Poll Results: BB Mopar Head Options
Brodix B1 BS 1 16.67%
Edelbrock RPM Chrysler 440 3 50.00%
Indy SR 2 33.33%
Mopar Stage VI 0 0%
Voters: 6. You may not vote on this poll
Old 12-26-2006, 07:47 PM
BB Mopar Head Choices Going to finish up my 452 BB Mopar this summer and getting a little itch for aluminum heads rather than the 452's I have for it now. Everything is basic on this build except the custom D dish JE pistons I have sticking above the deck .013" for a tight quench with the 452 iron heads and a 10:1 CR. I plan on running on the streets on pump gas in a Cobra Kit Car. I am not looking for anything over .550 lift cams, .500-.510 is about max. I don't think a BB Mopar is going to have too much problem moving the car.
I don't have the valve train yet or intake and headers so not to much is holding me back from investing in aluminum heads. Any more questions and I will try to answer them by posting and re editing this first post.
I have not made any hard choice other than I want a bolt on replacement.
My options so far are:
Brodix B1 BS
Indy 440-SR
Mopar Stage VI
Old 12-28-2006, 01:54 AM
Crazy Mopar Guy's Avatar
More info- street driven, how much, what you consider "liveable" as far as cam, duration, LSA etc.... compression, etc etc etc....
B1'a and several Indy heads make good power, and Edelbrock and StageV1 heads in a light car wouldn't be too bad either depending on cubes, cam etc....
Old 12-22-2007, 06:53 AM
charger528's Avatar
there a good value in such a light car it will hall .Im using them on my 528cid mopar
Old 12-22-2007, 11:12 AM
Wiki Edits: 49
Originally Posted by QuenchPiston
[B]............ I plan on running on the streets on pump gas in a Cobra Kit Car. ............
Unless you're going all out racing you don't need to spend big $$$ on aluminum heads. In a Cobra kit car your problem isn't going to be manufacturing horsepower its going to be transferring that power to the pavement. Spend the money on the chassis rather than the heads and you'll be better off.
cylinder head cracked?!?!?!?! Blob Engine 4 01-24-2005 06:12 PM
what are the biggest valves that will fit a stock 440 Mopar head? Mad Maggot Engine 4 01-09-2005 12:28 PM
Cracked Head or Blown Gasket? '71 rag top Engine 1 12-15-2004 10:08 PM
Head Castings 69 chevelle SS Engine 1 10-05-2003 05:49 PM
BB CHEVY HEAD GASKET Studebaker Engine 1 02-07-2002 04:21 AM
