BB overheating - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-03-2002, 07:04 AM
Post BB overheating
I have a .010 overbore on a 454 Chevy with an RV cam and Holley 2-bbl Pro-jection set up. The engine is installed in a 67 Chevy C-10 carrying a Open Road chassis mount Class-C motor home body.
This unit is heavy (apaprox. 14,000 GVW when fully loaded and operated primarily in Arizona with engine A/C on.
Question: Does it seem reasonable for this set up to require:
1. Ron Davis custom NASCAR radiator (1" tubes),
2. Flex-fan on engine
3. Four electric pusher fans in front of radiator and a/c condenser,
4. Two combined transmission oil/engine oil coolers and 1 engine oil only cooler stacked behind one another and connected in series with a blower fan in front of them,
5. Air vents cut into engine hood,
6. Ram air intake ducting above hood air into throttle body,
to run at 220F when the ambient air is 105F?
I'm wondering why this set up runs so hot? I have had to add all these apurtenances to get this thing from 250 down to 220 on a hot day and the engine is not burning lean. The only thing I haven't tried is "wetter water" in the coolant system.
Any ideas why this set up runs so hot? I'm thinking about switching to a crate 502, but after all this heart-burn would like to salvage this set up before spending more $$.
Thanks in advance to anyone who cares to respond...jsc
Old 01-05-2002, 07:31 AM
johnnymopar's Avatar
Love your nails! You must be a Libra
Talking
jsc,
this seems very strange that your motor is overheating. it looks like you've done everything possible to eliminate a heating problem. I don't want to sound smart, but could it be that your temp guage is faulty? A 454 is a big motor, but if it only has a 2bbl on it, it's not like you're ready for the NHRA or anything. Is there anyway to check for a blockage somewhere in the system? Also, if your vehicle is overheating has your thermostat ever locked open? If it has then you know it is hot. This is a very peculiar situation. I know this isn't the same but, i saw a car with a 440 engine that used the factory rad from a '47 dodge and he didn't have any problems with overheating. Don't know if i'm much help. Hopefully you can get this figured out.
Good luck,
JB
"Well done is better than well said." - Benjamin Franklin (1706-1790)
Old 01-05-2002, 12:52 PM
Post
I would make sure your not running lean,I don't know how you've checked but its possible you are fine at low speeds or light load conditions. It could also be slow on timing which would also make it run hot.
Old 01-05-2002, 03:51 PM
Post
Do you have a shroud? It does make difference and, I've always known a clutch fan and shroud set-up to do a much better job than a flex-fan with or without(a shroud). In this case I don't know if this will help or not because after all toteing all that weight can really be hard on a motor.
Old 01-06-2002, 03:43 AM
awsum34's Avatar
Post
are you over heating sitting still or at hiway speed? At hiway speed your fan dosen't help, the air moves in faster than the fan can move it in.
Where is your sending unit located at? Depending where it's located your get different readings.
If your running under size pullies will make it run hotter.
To me it sound like you have to many things mounted to the radiator and blocking the air flow.
If your a/c condenser is mounted up against you radiator that will cut down on your air flow, Your fins block the air from the fins on the radiator, should be around a 1" or more from the radiator, that way the air can flow thru both. (put some foam between the outside edge of the condenser and the radiator, to fill in the gap. that way the air will be forced thru the radiator and not getting out between them).
If you want to check out more about overheating go to <a href="http://www.streetrodstuff.com" target="_blank">www.streetrodstuff.com</a> there's a article about overheating.
Old 01-15-2002, 07:02 PM
New Member
Talking
Hey opionated, I'm in Mesa, I know what you're going thru. With that big of a rig, 220 ain't bad, I have a crew cab dually, all I do is tow my flatbottom and it get's that hot in the summertime with the A/C on. As long as it don't detonate when you get on it, it should be ok, don't run more than 36 lead on it in the summer, if it detonates, you might want to fatten it up a bit. Here's a tip I learned that helps a lot: By the time air goes thru the coolers and everything, that air is already 20 degrees hotter, mount the coolers on the side that the water enters the radiator, that way you won't heat up the air before it hits the radiator and run a 180 thermostat. Do you have one of those small auxialary fans? Mine has one from the factory, they work great, you might want to put one of them on...If the most you run is 220, don't worry about it, just make sure the system is in good shape..........Hope this helps.........Good luck....
Old 01-18-2002, 08:18 PM
New Member
Post
Where are you sensing engine temperature from....if you have pulled your idiot light sensor out of the head and installed an aftermarket gauge in that location you are sensing temperature in the wrong spot. In that case you should be plugged into the intake manifold near the thermostat...not in the head. I made this mistake and corrected it and the indicated temperature is fine now....Scott
Old 01-20-2002, 03:35 PM
New Member
Post
...everything has been mentioned that can be I think..... you didn't say how big the rad was.... is it stock 454? Bigger is always better there...and like the guy from Mesa said... 220 ain't bad!!!! you ain't gonna hurt nothin' there.
You're workin' the tar out of that motor with a two barrell... got a four in the garage? I'd bolt it on... hope we all helped some...
CrazyCraig
CC sez: "Car trailers should be outlawed"
