-   General Rodding Tech (http://www.hotrodders.com/forum/general-rodding-tech/)
-   -   BBBuick into FBODY (http://www.hotrodders.com/forum/bbbuick-into-fbody-215989.html)
430wal 03-04-2012 01:06 AM
BBBuick into FBODY
Has anyone performed a BBB or Olds swap into 2nd generation F body? I got an OLDs and Buick 455s and figured I'd drop one in. Any preference?
joe_padavano 03-04-2012 07:05 AM
Can't speak to the Buick swap, but the Olds swap is a bolt-in. Use the motor mounts for a 403 Trans Am and any 1964-1990 Olds V8 bolts right in. These mounts are unique in that there is a metal bracket that bolts to the block that attaches to the regular Chevy clamshell mounts on the frame.
430wal 03-23-2012 09:14 PM
Is the metal bracket a special adapter that would need to be obtained from a junkyard, or is it a parts store part? I already have what I believe is the chevy clamshell mounts from a small block I got from a 78 Impala. This metal bracket adapts the olds engine to Chevy mounts?
I assume the late 70's to early 80's Old's 307/350 mounts from full size BOP will not work on Firebird even though they are used on the same Olds small block?
327NUT 03-23-2012 10:09 PM
I love them both...but a built 455 Buick in a light Malibu :D :D
Valkyrie5.7 03-23-2012 10:26 PM
It's a parts store part. $6 brand new for a 403 olds-powered firebird motor mount on rockauto.com
