is a BBC 396 crank same as 427? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2006, 04:29 PM
bigwildgrin's Avatar
Rooster
yes, I know they have the same stroke but are they the same? GM listed some with the same casting numbers, but others have different casting numbers within the same year, for example a 3882841 is a 396 crank from '65-71, and 3882842 is a 427 crank from '65-'69. If they're the same why the different #? I read an old thread where a guy said they are balanced differently. He said you can put a 427 together with a 396 crank but the balance would be way off. Anyone know?
Old 03-12-2006, 05:24 PM
Some of the 396 crankshafts do balance differently.......
When I worked at the shop where we balanced engines......w changed extra for SOME 396 crankshafts.....in a 427. If I remember correctly....they were considerably lighter........maybe the 65,66,67 Models....but this was over 25 years ago........so I could be wrong on the years or models....
Old 03-12-2006, 06:49 PM
BOBCRMAN@aol.com's Avatar
Duece, you are correct.. 366-396-427 all fit in the same space but are balanced differently. Especially when you get into the tall deck/truck motors with the HEAVY pistons..
Old 03-12-2006, 07:19 PM
Sandflea427SS's Avatar
Anything with a throttle
4.094 for the 396
4.250 for the 427
the 396 piston would weigh less hence the lighter counterweights on the 396 crank
Old 03-13-2006, 09:38 AM
So then material should have to be removed from the 427 crank to stuff it in a 396?
Old 03-14-2006, 10:57 AM
the only thing i can think of is that the counterweights are different in weight and placement.
Old 03-14-2006, 11:14 AM
I am just guessing here, but I can't think of any reason the weights would be in a different location. I have a 6223 steel 427 crank at the engine builders now to go into a 396....he hasn't said anything.
Old 03-14-2006, 12:15 PM
Old does not mean dumb
The weight (counterweight) is in the same location. There is just less of it because of the lighter 396 piston. Some are shaved down and some have holes drilled in the counterweight.
Old 03-14-2006, 01:15 PM
Rooster
so it would seem that this would ba a good thing.... lighter crank= less rotating mass. or am I just being dumb?
Old 03-14-2006, 06:37 PM
Bumpstick's Avatar
Hammer and a torch
Yes lighter is better but you would have to be sure and have the assembly balanced to make a 427 from a known 396 crank... Not just a throw it together combo...
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
Bbc 427 z3pr Engine 7 01-07-2006 04:30 PM
A 454 is a 427 with a crank or rods or what? esears Engine 10 07-01-2005 06:50 PM
500 crank in a 427 tall deck? brian12c Engine 3 04-25-2005 07:52 PM
396 0r 427 in 78 camaro myrl Engine 6 02-03-2005 06:43 PM
