-   -   Bbc 402 Installed In A 1980 Z28 Camaro What Should Be Installed For Coil Spring (http://www.hotrodders.com/forum/bbc-402-installed-1980-z28-camaro-what-should-installed-coil-160477.html)
Glen Rogowski 06-21-2009 12:44 PM
I Will Be Putting A Bbc 402 Into A 1980 Z28 Camaro With Cast Heads. What Should I Be Using For Front Coil Springs?
ericnova72 06-21-2009 02:55 PM
I would think the Big Block 1970-72 Camaro spring would be a good choice. This size spring (5.5" dia) is also a common circle track spring, you can pick them by spring rate this way and they are fairly inexpensive ($50 ea), especially compared to restoration house prices.
Glen Rogowski 06-21-2009 09:41 PM
Who sells the coil spring?
ericnova72 06-21-2009 09:57 PM
TRW and Moog sell the stock replacements, check Speedway Motors and JR Motorsports for the circle track replacements in 50 lb or 100 lb increments. Virtually any circle track supplier has these.
Is this to be a street car or drag car? There is a big difference in spring rate.
