Bbc 427 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-02-2006, 12:10 AM
z3pr's Avatar
A legend in my own mind
Last journal entry: 78 El Camino
Bbc 427
Any opinions about the 427 BBC ?? In the near future I will be shopping for a 427 BBC too build. What kind of price range do you think I'll be looking at for a good rebuild-able 427 ???
Old 01-02-2006, 05:02 AM
Bumpstick's Avatar
Hammer and a torch
Will be several that will say just build a 454 but for those of us that like the big bore short stroke basicly small block of big blocks they are great.... (see the pic`s in my gallery)
They are getting harder and harder to find but are out there and most likely you`ll have to piece one together...? Cranks are cheap from $100-$250 and of course the 454 block will work perfect as will std. length rods... Pistons will be the more difficult area as will be the cost... Large oval port heads are the ticket (049` & 781 castings with the larger valves installed...)
Just say big blocks and big bucks and your on your way...
Old 01-02-2006, 10:25 AM
z3pr's Avatar
Well, I'll be in no big hurry. I have pleanty of time too search for parts and build this engine. Kind of nice being older and willing too spend a few years on a car.
Old 01-02-2006, 11:24 AM
firestone's Avatar
http://teamrfc.gospelcom.net
These should give you some ideas. For about the same price, you could build a 468, just something to think about.
http://www.racingjunk.com/exec/ca/vi...UCK-MOTOR.html
http://www.racingjunk.com/exec/ca/vi...440-CU-IN.html
http://www.racingjunk.com/exec/ca/vi...p-427-bbc.html
Most of these are already built or have been upgraded at some time, so you could probably get one cheaper that has not been touched but I thought this would give you an idea.
Adam
Old 01-03-2006, 07:52 AM
For the same money build a 496!
Old 01-03-2006, 05:16 PM
project69ss's Avatar
my 427 BBC (tall deck)
One block=$300.00 + three hour cruise.
Forged crank(3.76 stroke) by the general $350.00
Eagle 6.535 rods $400.00
Keith black pistons 9.5:1 $300.00
Machine work $595.00 (some assembly required)
Heads $100.00 (some assembly required)
machine work for heads $150.00
scorpion 1.7 roller rockers $200.00
comp tall deck push rods $140.00
Bearings $100.00
moly rings $90.00
weind tall deck intake $320.00
oil pump,pickup,pan,shaft,water pump,gaskets(nickel here,dime there)
still need cam,lifters and carb $$$$$
knowing there is no guarantee it will not blow up the first time I give it a hot supper=priceless
Old 01-07-2006, 01:54 PM
z3pr's Avatar
In all honesty, I'm kind of eyeing This 427 crate engine. That 7 year / 70,000 mile warrenty sounds pretty good to me. May not have all the preformance goodies, but I can always add those later on
Old 01-07-2006, 03:30 PM
Sounds like a fair deal.Even cast parts are o.k.for mild performance.Add the cost of shipping both ways or the core charge if you do not have an acceptable core.
427 BBC Timing 66Vette Engine 10 12-23-2005 12:36 PM
409 Corvette? MI2600 Engine 18 06-04-2005 09:34 PM
what is a tall deck block? bigwildgrin Engine 3 06-04-2005 04:58 PM
gas milage on a bbc 427 bet on black Engine 18 01-03-2005 12:32 PM
Anyone have a 427 BBC lying around? Infomaniac Engine 3 01-13-2003 02:38 AM
