BBC 454 Heads / Gaskets question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2004, 06:50 PM
rakundig's Avatar
I have a 454 Mark IV engine from a 70-75 vette.
About a year ago I replaced head gaskets but I am having a heating problem and I am thinking I may have installed the gaskets improperly.
I ordered a new felpro 1017-2 head gasket (same as I put in before) and I have been looking at it and a picture of the block of a Mark IV 454. The picture brings one big thing to mind.
On the top of the gasket there are small holes that are just over 1/8" in diameter. Looking at the picture of the block the holes they line up with appear to be about 1" in diameter.
The gasket has a built in "seal" around the holes that is just over 1" in diameter.
Am I supposed to cut those holes to fit the size of the holes in the block/heads? Or is that tiny little hole supposed to be that size and leave it that way?
I am attaching a picture with the holes I am talking about circled in red. The holes on the bottom (circled in blue) are the same size on teh gasket and the block.
Thanks
Rick
Old 02-03-2004, 09:01 PM
rakundig's Avatar
I noticed that people are reading this post but no replys yet.
If I need to provide further information please say so. Maybe I have not been clear enough.
Thanks
Rick
Old 02-03-2004, 09:11 PM
KA67_72's Avatar
What's the compression ratio?
What kind of octane fuel do they sell over there?
I'm assuming you're still in Japan. Is the fuel gas, alcohol, or some blend of the two?
Kevin
Old 02-03-2004, 09:39 PM
NorthStar's Avatar
Leave the gasket as is. The holes on block are made that big so sand from casting mold can be flushed out after its made.
If you were to make holes in gasket huge then you would really have cooling problems. Coolant would bypass the back of block and back cylinders would run way too hot.
Think about how water enters the block, flows past all the cylinders then is routed up through back of cylinder head and flows forward through the head to thermostat passage.
The little holes in gasket are meant to prevent steam pockets from forming.
Old 02-04-2004, 12:19 AM
rakundig's Avatar
Ok, I thought that I should leave them but I wasn't sure.
I am trying to figure out how to fix an overheating problem and head gaskets is my next step (if I have to).
I overheat sitting idle, 4 core griffin rad with shroud and 15" solid fan, no clutch. It blows enough air so that you can feel it at the windsheild with the hood up so I think I have good airflow. You can feel it pretty good at the front of the radiator getting sucked in. If you hold a cigarette in front of the grill the smoke gets sucked in so I think I have pretty good airflow. The fan doesn't cover as much radiator as I would like but I think i will work on that as I can. I will need to move the radiator around in the engine compartment to get a larger one to fit the shroud.
I am using either 87 or 94 octane fuel, depending on if I buy on base or at a japanese gas station. It is not alcohol mixed.
Would an alcohol mix help cool me off? Could my gas cause overheating. I think I heard higher octane burns "cooler".
I don't know my compression ratio but I would guess it is around 10:1. Maybe slighly under. It can run on pump gas.
Thanks
Rick
before I change head gaskets I am going to do a few tests.
Compression checks look good (already did those)
Don't see water in oil or oil in water
I have ordered a test kit to see if there is exhaust fumes in the radiator indicating a microfracture in the head gasket allowing combustion gasses into the rad. If that is the case then off the heads come.
Basically i just wish the darn thing would quit overheating.
In 40 degree weather she runs up slowly to 160 degrees (I put in a new 160 thermostat last week, had 180) then stays there for a good 15 minutes.
Then she will SSLLOOOWWWLLLY start to climb. In the next 5-10 min she will be at about 190-200, she will keep climbing.
I sat in her and gave her gas to 2000 RPM in park and the temp gauge quit climbing for the most part. It still seemed to climb but it was so slow that you really had to pay attention.
Driving around in 40 degree weather also seems to stop the climbing (10 mph) but she won't cool down any. Once I stop she climbs again.
What I am trying to figure out is if this is just the way she is or if something is wrong. (It is a 70-75 vette 454 after all)
I know I can run her up at 210 with no problems but I am afraid to go over that. I have a couple of times in the past, almost 250 once when I wasn't paying attention (this is before the shroud/fan/radiator swap)
I haven't let her run up since then.
Any ideas about if I am really overheating or just running normal or suggestions are always welcome.
Thanks
Rick
Old 02-04-2004, 12:44 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
Check the sending unit and the gauge, are they matched up or just something you put on that looked right? Sending units do go bad. Is the fan in the right position in the shroud? You should be running a clutch fan, probably a 7 bladed one.
Do you have to add any water?
Those small holes in the head gasket are there to restrict the flow for cooling purposes.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
Old 02-04-2004, 04:48 PM
rakundig's Avatar
I am using a matched sending unit and guage. Brand new electric.
I was using a matched mechanical gauge but was worried it was not accurate so I got another one (the electrical) and it shows same readings
I am full of water and am using an expansion tank
I do have a clutch fan but I am not sure I will be able to fit it in the shroud. It is very large, it does pull alot of air and works better than the 15" no clutch but it's size is a problem, it gives me just millimeters clearance between the blades and the hood.
The fan I have is not centered in teh shroud. I am going to have to move the radiator around to get it centered.
The 454 is just damn big.
Thanks
Rick
Old 02-04-2004, 07:55 PM
GTO 1965's Avatar
does the shroud go all the way to each side of the radiator and all the way to the top and bottom is it up against the radiator tight, are the fan tips within an inch of the shroud all the way around if not the fan is pulling most of the air between it and the shroud, does the car have a/c if so make sure the condenser is not plugged with bugs and road debis. Hope this helps!
Old 02-04-2004, 08:43 PM
rifraf's Avatar
I bought a 1 ton gmc 454 a couple years back,the poor guy spent a ton of money trying to get it to cool down,he gave up and sold it to me cheap,it had new everything. To make a short story long,the new water pump he was sold had the impeller for the V belt,my point is that they appear identical and there are two different rotations,got the right one?
Old 02-04-2004, 11:03 PM
rakundig's Avatar
I need to work on shroud/fan clearance. The shroud is 18" in Dia and the fan is only 15" and it is slighly offset leaving just over an inch on two sides and under a half in on the othe two sides. I am going to have to move the radiator to get it to center.
The shroud is perfect, fits exactly to the radiator, tight, covers all but a few millimeters of the core.
no ac
Not sure what you mean but I have two long waterpumps and I have tried them both. I can see flow in the radiator so I know water is moving.
They are V belt pullies but I couldn't say about the impeller. One of the pumps I got directly off a vette and my engine is a vette engine.
Old 02-05-2004, 06:36 AM
rifraf's Avatar
Well,my truck uses the same long style you use. Many of the serpentine belt motors wrap the belt in a way that turns the pump the opposite direction,they run off the back side of the belt,to make this work,they changed the shape of the blade inside,it will still move the water but not near as well as it is supposed to. You cant tell appearance wise from the exterior.
