BBC 454 hp estimate - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2013, 02:12 PM
BBC 454 hp estimate
Hi guys,
Fairly new here and am building 454 and am curious what hp numbers I might have. First BB. Had a few SBC's..
Ok, I have a .30 over 454 (2 bolt main with all ARP bolts on everything)
Forged stock crank
Truck 7/16th reconditioned rods.
Forged pistons
9.5-1 compression
049 heads cut to 2.19 /1.88. Unshrouded and mild port work
SS valves with roller tip rockers
280 magnum comp cam / 2k-6200 rom range
Single plane weiand w/ 750 DP Holley.
Exhaust unknown yet...
Am I in the realm of close to 550hp ya think???
Decent combo????
Thanks all!!
Old 02-20-2013, 02:31 PM
vinniekq2's Avatar
maybe a little over 400.How did you decide 550?
an LS-6 454 with 11:1,full floating rods,square port heads,Al. intake,780 carb,big cam makes or is rated less than 500 hp
Old 02-20-2013, 02:32 PM
Just ballparked it.... No rhyme or reason....
Old 02-20-2013, 02:44 PM
vinniekq2's Avatar
the torque should be over 500#.should go well,depending on the vehicle?
Old 02-20-2013, 02:48 PM
Yeah, just wanted a nice solid motor that would run to 5700-5800 without busting anything... Hopefully this will suit my needs... I'm debating it in my 1/2 ton pickup or my v-drive boat......
Old 02-20-2013, 03:16 PM
vinniekq2's Avatar
if its a small rod motor,change the rod bolts and put good valves in the heads.The rat is a lot of fun.
BBC 454 Mark 4 heads going on a 454 Mark 5 block? c65shoebox Engine 2 03-14-2012 10:03 PM
454 HP and Torque Estimate 31fordcoupe Hotrodding Basics 5 05-05-2010 11:50 PM
Power estimate of mild/stock 454 kahl_454 Engine 15 01-05-2010 02:52 AM
454 power estimate 81malibu Engine 10 10-31-2009 06:31 PM
454 BBC Vs. 454 SBC differences and why...? Bumpstick Engine 4 11-02-2005 01:26 PM
