bbc 454 maximum power engine build up - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-07-2003, 03:26 AM
Wink bbc 454 maximum power engine build up
I own a 1971 camaro, with a 350, however, it is old and worn out. My buddy has 3 chevy 454 blocks, one has to be a good rebuild candidate. My question is this, how do i get the absolute most amount of horse power from this build up without supercharging? Should i use a stroked crank? If so, what size rods will work? Compression ratio? piston brand? heads? roller? camspecs? I'm looking to go all out on this motor, shooting for 600-700 hp. Car will be a streetable drag car. Any race proven knowledge is greatly appreciatted. Thanks.
Old 07-07-2003, 01:29 PM
WV hillbilly
Last journal entry: PTL 220CC
depending on the cubic inch youd proboly need 13:1 to acheive 750hp, on the other hand, you could proboly attain 600 hp easy with 10:1 with the right parts...I would at least stroke it to 496 CID, the biggest I would go with a stock block would be 505CID 4.250 stroke 4.350 bore..a good set of heads are a must, imo Dart, AFR, Canfield etc...make good heads to make your goals easy and most likely youll have to go with a solid roller cam matched to your combo...600 hp isnt that hard to come by, 750 is a little more tricky...Id just add a little N2o to make up the differance...just my .02
Old 07-07-2003, 03:10 PM
gt2betubbed's Avatar
Kid With A Wrench...
Last journal entry: The Blower and test fit.
Stroking would be the way to go, as they say, "there's no replacement for displacement". I don't know the specs on a 496 stroker, but there's a guy on this board that's building a 496 twin turbo. Do a search on it and see if he can help. Also, I don't know how "streetable" a 600-700 HP motor is going to be. I hope you are willing to do a little of sacrificing since they usually operate in the higher rpms. Make sure you don't skimp on the cooling system also. I'd go with an 11:1 comp piston that's forged and from any reputable company. And like 2wld said, it's going to all be in the heads... Good luck!!
Old 07-07-2003, 05:35 PM
This is the list of parts you might use to make:
600 Ft lbs. of torque @ 4500 and 670 HP @ 6000
Bore 4.130 Stoke 4.00 Rods 6.135 = 467 CID
Dart Iron Eagle Heads 345 CFM 119cc Chamber
Lunati Factory Performance cam I Duration 264 I Lift 560
E Duration 270 E Lift 580
Roller Rocker Arms 1.7 Ratio
Lunati 11.1 32cc dome volume Pistons
MSD Distributer Holley 750 Carb Edelbrock Performer Air Gap Manifold
More Cubic inches, more compression or larger cam might make even more. Hope this helps
Joe
Old 07-07-2003, 09:38 PM
You can make 650 hp with most 454 blocks even 2 bolt mains,so dont worry about the block.I would seek out a factory steel crank,and have it machined to spec,and the oil holes chamfered.Bore the block .060" over,deck to zero clearance,and fit it with forged pistons of about 40cc domes.You can make this power with stock rods,but I would prefer a set of mid priced H beams,and add .250" to the rod length just to get the piston weight down.Run a solid flat tappet cam with about 255 intake and 265 exhaust at .050",and .620 lift with a 108 lobe seperation angle and a 102 intake centerline.You can make this power with ported oval port heads or out of the box iron rectangular heads such as the GM 188 casting,but in all honesty,you will save weight and have better heads for a screaming deal by investing in a set of edelbrock RPM rectangular port heads.Take them out of the box and have the valve job checked,and maybe give them a bowl blend{I do this to any head no matter how good it is}.Have the springs checked,and bolt them on with felpro type gaskets.You dont need a trick valvetrain for this budget,but you should look into roller rockets{1.7:1 hartland sharps will do just fine} and hardened pushrods and guidplates.Top it off with a gasket matched 454R edelbrock intake and 850cfm double pumper.Run 2" primary tube headers and 3.5" mufflers.I run this type of setup with a locked out MSD billet distributor and 6al box,but an advance curve thaty allows maybe 12 degrees of mechanical advance might make it a bit more drivable.This isnt really a pump gas motor,it will cruise on pump gas,but if you want to race it,it should be at least 50% race gas.This setup in a 3500# car would run low 10's with a 4000 stall convertor and the equivilent of 4.56:1 gears and 30" tall tires.Good luck.
Old 07-08-2003, 03:09 AM
Honorary Redneck
Originally posted by Super Streeter
You can make 650 hp with most 454 blocks even 2 bolt mains,so dont worry about the block.I would seek out a factory steel ...
see, now all I heard was bla bla bla bla, see that button on the right that gots "Enter" written on it, and a arrow on it, try hitting it occaisionally
Old 07-08-2003, 03:07 PM
WV hillbilly
I know alot of guys that build 600hp motors and end up with 450hp...what ever you do match everything up, if you have a set of heads that flow 500cfm and use a dual plane, your not going to make alot of Hp..... its important to know the flow numbers of the heads, and intake to properly match a cam to not only the cfm of both the intake and the heads but also to the compression ratio and rpm range...Im not going to get into piston speed and its importance to the heads and cam used ,just be sure to match up your parts and no matter if it makes 600 or 1000 hp you will be happy with the results...see now Ive spend .04 :laugh:
Old 05-17-2015, 11:45 PM
ponomo customs
i need help on a 454 bbc build
This what I have scat cast crankshaft with scat pro-stock I-beam forged rods wiseco fully forged 4340 steel pistons size 4.280 dome volum +20cc dome top. A set dart pro 1 aluminum cylinder heads wth 121 cc chamber 275 cc intake runner with 2.190 intake exhaut 1.880 valve. I need help with pick a cam and intake. want to know if I can get 600 hp with a/c if so what cam will work
Old 05-18-2015, 07:37 AM
RWENUTS's Avatar
Holy thread resurrection Batman!!
Now you've got your info on 3 threads!
Old 05-18-2015, 09:08 AM
ponomo customs
I'm new here I need help
Old 05-18-2015, 02:52 PM
BBC 454 maximum power build up
If you are wanting to build an engine with more than 700 HP I would start with something like this not a small cubic inch factory block. CNC Competition BB Chevy 540 Dart Short Block, Scat Crank, Icon FHR 10.0:1 Pistons | CNC Motorsports | Car Parts | Truck Parts | Competition Engines The only thing that I would call CNC Motorsports is replacing the 4140 Forged steel crank with a forged 4340 steel crank. This is the way to start now you concentrate on the heads that you will use. These heads will get you more than 700 hp. BBC Sniper X CNC Ported Cylinder Heads. Then get a Victor Jr with a 950 cfm Holley. You get to research the camshaft but I am certain you will have to choose a mechanical roller camshaft for the hp you want.
Old 05-18-2015, 05:17 PM
ponomo customs
Thank u for yo help
Old 05-18-2015, 11:24 PM
What's the most? How much $$$ you got? My buddy has a 468 setting in his shop that only 11:1 and has been dyno'd @ 740 hp and will do it on 93 octane with some octane booster. Here's the kicker, He's got about $7000 just in the heads and rocker arms. Consider you'll end up spending as much on the car as the motor. What can you spend?
