bbc 454 pistons - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2010, 08:03 PM
bbc 454 pistons
i have a 96~99 bbc 454 and the pistons are two valve relief and the number on top is 12563092 and i am trying to find the compression on them any help will be helpful
Old 09-14-2010, 08:10 PM
techinspector1's Avatar
Wiki Edits: 326
Finding static compression ratio requires knowing 5 different values.
1. cylinder volume in cc's
2. chamber volume in cc's
3. piston deck height volume in cc's
4. piston crown volume in cc's
5. head gasket volume in cc's
If you want it done right, pull a head and start measuring.
You add all the values together, then add all the values together with the exception of the cylinder volume. Then you divide the larger total by the smaller total. That is your static compression ratio.
Nobody said this stuff is easy. At least, nobody who has done it before.
stock bbc 454 vortec dre1984 Engine 13 08-09-2010 09:01 PM
What pistons are these?? (BBC) jjgrizz73 Engine 4 05-26-2010 08:11 PM
Mid 80's TOWING 454 BBC needs a facelift.. Please help MuscleBlock81 Engine 6 01-21-2007 08:36 PM
454 BBC Vs. 454 SBC differences and why...? Bumpstick Engine 4 11-02-2005 12:26 PM
bbc 454 buildup Triplany Engine 9 01-15-2004 07:12 AM
