Can you give use current rear gearing, tire diameter, and current finish line rpm?? Currect ET amd MPH?? Vehicle weight??
Torque converter diameter?? Current stall rpm?? Current shift rpm?? what transmission?? Was the closed chamber deshrouded when you had the bigger valves installed?? chamber modified any at all?? Once you answer these questions we'll have a better picture to go with the above advice. |
9" Ford narrowed 4:30 gears 33x16x15 Hossier slicks (I know I should go smaller but have to keep) Finish line RPM w/4:30 is 5700 - Had 4:56 and was 6200 ET is 11.6 @ 117mph Vehicle weight is unknown. Guessing around 3000 Converter is a 9" 4500 stall Shifting at 5500 TH400 w/transbrake I worked the bowls and gasket matched the heads myself. The machinist that did the heads and valves said they looked good (for whatever thats worth). I was just smoothing up the casting. |
I agree with most of what Pete @ Hughes has told you, with a couple exceptions.
He is right, you need to turn more rpm, even with the cam you have now. Shifting at 5500 rpm is cutting 1000 rpm of your best power out of the equation. I'd go back to the 4.56 gear. Does the engine feel like it really falls off above 5500rpm?? I don't feel the 1150 carb is a problem, yes it is too big at the moment but would be great when the combo runs like it should. O all the things he listed it would be the last I'd look to change. I'm not sure concerning his reference to the Holley Blue pump, I've used it on 1/2" line and have friends that do so too with no problems. Have you measured fuel pressure during operation, near/at the finish line to see if it isn't keeping up?? He is correct about too restrictive a filter on the inlet side, best too use a 40 micron screen here to protect the pump, then a finer filter after the pump. The larger cam will help, but I don't think it will do a lot with the present combo, which brings me to the parts I would change if it was mine...The heads. Two things bother me here, first the Oval port...I am not a Oval port guy, and neither are my friends. Every Oval port engine(using a stock head casting) I have ever seen has left me less than impressed. Sure, they get all the ink in car mags and on forums...but the engines most are using them on are 2500rpm to 5500 rpm engines, and that 5500rpm point is about 500-700 rpm above the point they seem to fall off power on any engine I've seen them on. In your case, you are leaving the line at 4000-4500 rpm, you have already given away 2000 rpm of the Oval heads strong point and are near the engine's torque peak, and with a small head once you go past the torque peak power falls off rather quickly if the head can't flow enough to support the higher rpm. Second problem with the heads is the closed chamber, along with bigger valves and the chamber not being ground out to a semi-open configuration to unshroud that bigger valve. I would not be surprised that if put on a flow bench that they flow worse than they did with stock valve sizes. Seems like maybe in this build you overemphasized the importance of compression, and this was the reason for choosing the 215 head?? I think the opposite - emphasize airflow and worry less about the compression ratio. Be 1-1.5 point low on the compression for the cam choice and you loose 30-40 hp...but by comparison, have poor heads and you lose 100+ hp. If I had your engine the heads would be the first thing changed, before anything else, even the cam or rear gears. Get a Rectangular port head, either iron Merlin, Dart, or RHS bare castings and transfer all the parts out of what you are using now, or even a bare set of the Procomp aluminum castings(PM Bobcrman here at Hotrodders, he has used them many times with good results) fitted with your parts. You are launching at an rpm high enough you don't really care how much low end torque it makes, it's meaningless; the engine is large and you are nearing the rpm it makes peak torque at...now you need airflow so the power doesn't die off just when the rpm is getting good. Once you have a good head, the 1150 carb won't be a problem, and with a good head the cam you have will run right up to 6500+ rpm just fine. Should be able to port match your Oval port intake to a Rectangle head, usually it is only the last 1.5-2" of port that is oval in the intake manifold. Again, I would dump the Oval port heads, i have never seen a engine with them that has impressed me. |
Now comes the question of what size of head should I look for, runner and chamber size and anything else I need to look for in chosing a head for this combo? Also, would a head with even larger valves than what I have now (2.19 x 1.88) work better? Thanks Last edited by S10 Racer; 03-07-2011 at 09:04 AM. |
I'd be looking for a rectangle port head in the 305-320cc range, with 2.19" or 2.25" intake valves and 1.88" exhaust valves. You could use a 2.30" intake valve if the head you like comes with them, but it probably won't need the extra size until you really get the rpm up(7500+).
You could also look at the smaller volume rectangle port (294cc) port Brodix Race Rites or the Edelbrock Rectangle (300cc). You need to have a 110cc chamber to keep compression at 10.8-1 with the L2349F (as it is a smaller dome shape meant for closed chamber heads), 116cc gets you 10.2-1, 119cc gets you 9.9-1. Looks like just about any head you choose will have to be milled some to get you a decent ratio, as most all aftermarket heads come 118-119cc. Right now it appears you are around 11.6-1 with the undecked block and 101cc 215 heads chamber, looks like a 119cc head milled .040" should get you to 10.8-1 roughly. You could mill them farther to try to keep as much compression as you can but it may require intake milling also. |
Summit Racing Part Number CCA-11-220-4 UPC 36584540168 Cam Style Mechanical flat tappet Basic Operating RPM Range 3,000-7,000 Intake Duration at 050 inch Lift 260 Exhaust Duration at 050 inch Lift 260 Duration at 050 inch Lift 260 int./260 exh. Advertised Intake Duration 306 Advertised Exhaust Duration 306 Advertised Duration 306 int./306 exh. Intake Valve Lift with Factory Rocker Arm Ratio 0.629 in. Exhaust Valve Lift with Factory Rocker Arm Ratio 0.629 in. Valve Lift with Factory Rocker Arm Ratio 0.629 int./0.629 exh. Lobe Separation (degrees) 110 Intake Valve Lash 0.022 in. Exhaust Valve Lash 0.022 in. Computer-Controlled Compatible No Grind Number CB 306S-10 |
Not really any difference in durability of aluminum heads vs cast iron, that is mostly a wives tale. With the aluminum head you get light weight(big plus with BBC) and repairability if something goes wrong(you can weld them). You just have to not be ham handed with the threads in aluminum is all...follow recommended torque specs. Antiseize on spark plugs and exhaust bolts. Plus there are always helicoils if a thread gets hurt, a helicoiled hole is stronger after the repair than a simple threaded hole in the aluminum casting is in the beginning. Some companies helicoil all fastener holes in their heads from the get-go(I think Brodix comes to mind).
About the only plus to iron is the lower buy-in cost. Both will perform the same if they are an identical port casting, like comparing Dart Iron Eagle and Dart Pro 1. A stud girdle is good protection for the stud posses in the aluminum, along with preventing flex in the studs with the BBC compound angle and big 1.7 ratio, so it is good to have a girdle on both Aluminum or Iron. I like the bigger cam grind. I would definatle put a face-oiling lifter on it though if you use it, BBC is hell on flat tappet cams. I've used that Comp grind in a 460 Ford years ago, it worked well with the large port Super Cobra-Jet heads. Went mid-10's in a 2800lb '66 Mustang with an 8" converter and 4.30 gears w/31.0 x 16.50 tires. Shift point at 6000 rpm. |
| power steering pump for sbc with MustangII power rac | TheCiscoKid | Suspension - Brakes - Steering | 5 | 12-29-2012 05:39 PM |
| Power Disk and Power Steering | Great '48 | Suspension - Brakes - Steering | 7 | 09-05-2005 08:35 PM |
| 67 nova power sterring not power assist? | turbonova | Suspension - Brakes - Steering | 6 | 12-20-2004 06:52 PM |
| power brakes and power steering on a '63 impala SS | Benni520 | Hotrodders' Lounge | 2 | 10-14-2002 09:49 PM |
| anyone know anything about putting power brakes and power steering on a '63 impala SS | Benni520 | Suspension - Brakes - Steering | 0 | 10-14-2002 01:22 PM |
