bbc 468 combo help - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2010, 10:50 AM
bbc 468 combo help
I am building a bbc 468 hoping to make at least 600hp and torque. My question is I am needing help picking the right can I know I want a solid roller but don't know which one to choose and as far as the heads I have two sets of stock casting 049 and 390 and dont know which ones are the best to use. The 390 are fully work 2.19/1.88 valves, bowel work,chamber work and gasket match on intake and exhaust. I have a dart single plane 950 Holley compression around 11 open to any suggestions thanks
Old 04-12-2010, 11:00 AM
techinspector1's Avatar
Wiki Edits: 326
Into what will this motor be bolted? What will be it's primary purpose? Street only? Street/Strip? Strip only? Mud bog? What? Will the motor have to run on pump gas?
Old 04-12-2010, 03:35 PM
Its going into a 1979 Monte Carlo not a daily driver and for the street/strip. I don't mine mixing race gas with regular gas
Old 04-12-2010, 05:07 PM
BOBCRMAN@aol.com's Avatar
I have had great luck with cams around .660-.680 lift. With moderate durations and a 112 centerline. They are easy on parts, idle, take nitrous or street blowers well and make tons of power with GM casting heads.
efi on 468 bbc roadkill468 Engine 0 08-21-2009 09:32 AM
what do you think about this combo (468 chevy pannel) pannelcrazy Engine 0 08-13-2009 10:05 AM
Building a blown 468 bbc [ questions] Bad Rat Engine 8 12-08-2006 12:49 PM
468 bbc hp and tq?? 468ci1956 Engine 3 11-09-2006 03:00 PM
BBC 454 combo NOlowrider Engine 3 03-28-2006 06:26 PM
