bbc 496 combo help - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2010, 01:14 PM
bbc 496 combo help
I am building a bbc 496 for the street/strip hoping to make 600hp and 600tq so I need a little help with this setup and the heads I have are the close chamber 390 that fully work to the Max and I have the open chamber stock 049 also looking forward to using a solid roller
Old 04-25-2010, 02:28 PM
BOBCRMAN@aol.com's Avatar
What specifically are you asking about?
I have built several of these engines using KB domed hyper pistons and o49-781 heads, converted to 2.19-1.88 valves. This setup along with .660-680 roller cam makes a good running powerful, street engine.
Old 04-25-2010, 03:39 PM
What I am needing help with is with the 496 makeing big horsepower and torque will it be okay to use a set of fully work close chamber 390 or 049 the 049 have not been work yet
96 FireBird 496 BBC tickey8 Introduce Yourself 3 10-20-2009 09:38 PM
496 bbc intake and carb ?s tsmall114 Engine 12 10-05-2009 08:55 PM
Sould I build 496 or 468 BBC?? Help. MuscleBlock81 Engine 11 09-09-2009 02:14 AM
496 BBC buildup BBstroker Engine 3 04-12-2007 08:14 PM
BBC 496 or 525 sb72elcamino350 Engine 2 10-20-2004 09:40 AM
