Bbc 496 first time build - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2011, 07:21 AM
This ia my first time putting a big block together to race I have most of my parts so far block bored 60,probe forged dome pistons 10.1 stock 049 heads big valves bowl work and port, dart single plan intake ported, 850 carb, h beam rods 6.385 eagle 4.25 crank I am going solid roller need help on how much lift I need to get to 600hp and would this be a good set up for a 1980 monte carlo
Old 05-18-2011, 10:31 AM
what gear and stall converter?
10:1 cr needs a cam in the 290 to 300 duration range (advertised).
Don't go too crazy with the lift as that will wear out valve train parts in a hurry. I would try to stay under 0.600".
Furthermore, a LSD 3.73 gear with a 27 inch tire and a 10 inch 2800 rpm stall converter would work well with a 496 cid, 290 degree cam, and 10:1 cr.
bad frame, time to build a new one dodge it General Rodding Tech 8 12-29-2010 11:50 PM
first time build just dont know Introduce Yourself 2 01-23-2010 04:35 PM
first time truck build lavitzs187 Hotrodding Basics 2 05-25-2009 03:28 PM
High build top coat time frame americanLT1 Body - Exterior 1 06-11-2007 10:00 PM
Almost build time, still fuzzy on something. lozinit Engine 2 11-27-2002 07:12 PM
