BBC 540 Flex plate doubt - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2010, 08:23 PM
I am adapting a 540 BBC/Mercruizer in a 61 Impala.The car will use a TH 400 tranny.I have to switch from a fly wheel to a flex plate.Does any one know if there is a properly balanced flex plate that I can buy? Its a MK IV tall deck with Rec port heads and a regular rubber damper engine.
Thanks
Paulo
Old 06-24-2010, 08:49 PM
BOBCRMAN@aol.com's Avatar
To do it correctly.. You send the flywheel and a 454 Mark lV flexplate to an engine balancer. Balance guy will then find imbalance of flywheel and match the flexplate to that...
Cracked Flex Plate mikewheel Transmission - Rearend 4 01-04-2004 06:54 AM
New 327 flex plate for th350 pretorin Engine 1 11-30-2003 08:25 PM
What`s a good Flex Plate? KeithB123 Engine 1 09-23-2003 05:38 PM
t350 to 327 flex plate problems Armond Transmission - Rearend 1 09-16-2003 12:55 AM
Flex plate switch ?? Ed ke6bnl Engine 3 08-08-2003 06:50 AM
