bbc assembly - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-12-2004, 05:23 PM
Last journal entry: More propane stuff
bbc assembly
I am in the process of putting my big block chevy back together. When I disassembled the engine I stamped all the rods 1,2,3....
I am now on number three. I have the dot on the piston to the front (the stamped number is now not where it was when I made them) when I torqued the cap down and push the rod over for number 4 the small end of the rod is touching the piston, whereas the others have a 1/8" gap on the closer side. Is it possible the machine shop hung the piston backwards. Is that possible. If I put in #5 the clearance is fine. I am going to continue with the others but I have a few questions. Will it change the balance if I swap pistons. Is it possible that the piston is on the rod wrong. This is my first bbc so any help will be greatly appreciated.
Thanks
John
Old 05-12-2004, 05:25 PM
Rogers Performance's Avatar
It sounds like the rods are back wards the large chamfer on the big end of the rod should go to the cheek of the crank.
mike
Old 05-12-2004, 06:14 PM
Ok I am looking at the first two and it looks like they switched 3&4. I will try swapping them and since they are on the same journal it shouldnt effect the balance. Thanks Mike
John
Yup mike you were right. I swapped the pistons and everything is cool. This is what is so great about this site. I would have taken and idiot like me probably an hour to figure that out. Thanks again.
John
Old 05-13-2004, 07:24 AM
There is nothing wrong with asking questions.Its better then blowing it up.
mike
Old 05-13-2004, 08:07 PM
It looks like the machine shop did it to me again. Number 6 and 7 have the rods on backwards. I weighed them on my postage scale and they weigh the same to a .001 of an oz. Would it hurt to swap them to the different positions on the crank. If they weigh the same having them on different journals shouldn't matter should it? What do you guys think? I am asking because I have a full day at work and wont be able to get the rods to the machine shop for the guy to swap them till next week. If it doesn't matter I can have all the pistons in today.
Thanks
John
After a little thought I went ahead and installed the pistons. Time to head on home
Thanks again.
Old 05-14-2004, 06:19 AM
john if every thing weights the same you don't have to worry about witch journal it go on to. the only thing that would change that would be if the pistons were honed for that bore.
mike
Old 05-14-2004, 09:28 AM
Thanks again Mike. I checked the piston to wall and they all were withing the specs in my book. I didnt want to screw up my balance job. I hope the guy balancing it paid more attention than the guy hanging the pistons. Thanks again.
John
