Bbc bowtie heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-07-2012, 07:48 AM
Bbc bowtie heads
I have a set of bbc bowtie aluminum heads casting number 12363390 came of a zz502 and now going on a 468 and wondering does anyone know the flow number on these heads
Old 12-07-2012, 08:51 AM
hcompton's Avatar
Old & Furious
GM does not post flow numbers for those heads. With semi open chambers flow numbers may be missleading. I would assume they flow as good as most aftermarket heads if not better. and way better than any stock casting that came out back in the day on production car.
What is your goal.
Old 12-07-2012, 09:41 AM
My goal is to put them on a 468 8.7.1 compression and a b&m 177 blower with a 1050 dominator havent pick out a cam yet street and strip only 4,000lbs car
Old 12-07-2012, 10:10 AM
hcompton's Avatar
Old & Furious
Not sure of the spec of the 177 i googled for it but didnt find air flow specs. But it looks like it support 600-700 hp. If your looking for 800 plus better head towards a 8-71 style blower. But at that range stock block may not be able to take the power.
I think the heads will do the job. If you wanted 700 hp withput boost i would say they are too small and ypu wpuld need an all put race head but i think what you got should do the job. But i cant say for sure since i do not have the specs. I understand that is why you are here looking as well. Sorry i couldnt be more helpful.
I can tell you bowties for small chevy are good heads and will support 500+ hp under boost i cant imagine the big block heads wont do even better. Sorry for the useless info you probably already knew. Hope it helps.
Old 12-07-2012, 10:17 AM
vinniekq2's Avatar
Numbers are at 28" of of a SF600 Bench. This is flowed with a 4.500" fixture. Intake had radius fixture and exhaust is with 1 7/8" pipe.
GM #12363390 Alum Oval Port Head-stock
Intake Valve 2.250 " Exhaust Valve 1.800 "
Lift: inches Flow: cfm Lift:inches Flow: cfm
0.100 74.0 0.100 71.0
0.200 143.0 0.200 126.0
0.300 207.0 0.300 158.0
0.400 250.0 0.400 178.0
0.500 284.0 0.500 200.0
0.600 309.0 0.600 218.0
0.700 322.0 0.700 232.0
0.800 0.800
GM #12363390 Alum Oval Port Head-ported
0.100 85.0 0.100 73.0
0.200 161.0 0.200 141.0
0.300 230.0 0.300 175.0
0.400 283.0 0.400 208.0
0.500 332.0 0.500 234.0
0.600 354.0 0.600 257.0
0.700 361.0 0.700 274.0
0.800 363.0 0.800 287.0
Old 12-07-2012, 10:25 AM
vinniekq2's Avatar
if these flow numbers are accurate then a blown engine with these heads could produce up to 1,000 hp
Old 12-07-2012, 11:43 AM
Ok and thanks those numbers look good now all I have to do is find a cam next
Old 12-07-2012, 11:59 AM
vinniekq2's Avatar
Have fun.Just remember those flow numbers are with a 4 1/2 inch bore,your numbers will be a little lower with 4 1/4 bore.
No reason you couldnt port them,especially on the exhaust side for your application.
Bbc bowtie heads 12363390 dre1984 Engine 15 07-07-2012 01:21 AM
bowtie heads 14011049 joe morgan Engine 6 08-22-2011 01:34 PM
Plugs for bowtie heads Studebaker Engine 0 08-15-2009 04:22 PM
bowtie heads for sbc Eddie Baker Engine 3 11-08-2003 11:02 PM
bowtie stock heads Fireguy0712 Engine 1 08-26-2003 04:50 PM
