BBC Built, Loctite where? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2008, 09:57 AM
What bolts need Loctite for a BBC build? And red, blue or ???
thanks!
Old 10-16-2008, 11:43 AM
red requires heat to remove.....I'd stick with blue
Old 10-16-2008, 12:41 PM
Thanks, where would you put it? Cam bolts, oil pump bolts? What about mains and rods? Those are the only places I can think that might need it, but I dunno.
Old 10-16-2008, 12:54 PM
I'd do cam bolts, rocker studs, and (if you use them) cylinder and mainbearing studs where they go into the block. Be careful not to use to much, so that you bottom them out on the locktite. Just a dab'll do ya.
Pat
BBC MK VI and BBC MK IV Heads Mustangsaly Engine 3 02-22-2008 07:57 PM
Size difference between BBC and 460 ford junkyardjeff Engine 1 03-02-2007 03:35 AM
bbc what gears to run.? chevelle4542speed Engine 5 12-07-2006 05:47 PM
Loctite or assembly lube? staleg Engine 2 08-14-2006 05:08 PM
Assembly lube or loctite? staleg Engine 3 08-14-2006 08:19 AM
