bbc cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2009, 11:25 PM
bbc cam
i was given a big block chevy cam of some sort, i know nothing about it, all the specs were lost when he moved and he gave it to me knowing nothing about it. so is there any way to find out the specs on this mysterious cam? maybe bring it to someone in my area that could get the specs on it?
Old 05-24-2009, 12:25 AM
540neverdone's Avatar
Loves to spooge
Remove the timing cover, see if a manufacturers part number is on the front. If not, remove all lifters, keep them in order in relation the cam lobes they were on before, remove the cam, see if there are any numbers on the rear cam face. Nowadays, usually just googling the part number will direct you to sites with tech sheets. In the old days you would call the manufacturer.
Old 05-24-2009, 05:13 AM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
A quality cam should have some numbers stamped on the end.
BBC cam question inquiring_mind2 Engine 1 04-05-2009 07:18 PM
CAM Selection holding my build up (help) Carlos9 Engine 21 04-05-2009 12:34 AM
Anybody dealt with this guy on ebay? Or through Dirttrackthunder.com? killerformula Hotrodders' Lounge 20 08-31-2008 05:12 PM
What cam to go with Hyd. or solid (flat tappet BBC) Bumpstick Engine 2 05-02-2005 08:26 PM
BBC Comp cam EX274H, Impala5967 Engine 2 10-01-2003 08:53 AM
