bbc cam choice for tow rig - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-17-2012, 12:30 AM
vinniekq2's Avatar
I have about 11 in my 434 street engine,my 454 in my 80 Camaro had 2200,not counting the engine re build(came with the car).camaro ran high 11s
434 corvette not tested or set up for drags
  #17 (permalink)
Old 11-17-2012, 05:47 AM
Years ago, used a compcam 268H with stock springs in a 454. Ran ok until 4500 rpm then the valve started to float due to weak springs
  #18 (permalink)
Old 11-17-2012, 06:30 AM
If you want to go mechanical flat tappet and want strong torque & mid range. Check out this Comp Cams CL11-674-4 with part# 911-16 for springs. The specs are .527/.532 lift & 218/224 duration. LSA 110 I/C 106. Recommended torque converter stall rpm range 1100-1900 (stock). According to Comp Cams simulator peak hp is 352@4000 rpms and peak torque is 531@2500 rpms.
  #19 (permalink)
Old 11-17-2012, 06:36 AM
Banned
if you're try'n to get more out of the truck. and it's a budget..
I'll save you some cash..
if you are not willing to change the valve springs (100-150.oo) when you change the cam..
save your money.. really, don't bother..
as the truck will slow as the valvetrain floats.. AND can bend a valve or if you are really rally lucky, drop a valve..
you're on a budget for a reason.. I get that..
but whats cheaper.. the valve springs or rebuilding the heads because the valves are now bent? and STILL having to replace the springs..
just because the engine was free.. DO YOU HAVE THE MEANS TO REPLACE IT, when you kill it? thats not what I'd call a budget build.. but it's your truck/engine
good luck
never enough time to do it right the first time ,but, always enough time to do it twice AUTHOR UNKNOWN
please critique cam choice ap72 Engine 27 10-02-2008 04:23 PM
Anybody dealt with this guy on ebay? Or through Dirttrackthunder.com? killerformula Hotrodders' Lounge 20 08-31-2008 05:12 PM
406 Cam Choice HP52TA Engine 1 08-25-2008 08:47 AM
BBC 454 - Cam Selection - Solid vs Hydraulic - Help me Choose leejoy Engine 1 11-11-2007 04:45 PM
bbc camonics cam need id malibu396 Engine 1 10-15-2007 01:37 PM
