bbc cam id
I bought a 454 short block and I'm trying to find out what cam it is ??????
The #'s on cam are hr286-1 hr290-2 hr12 p6564
I just bought this short block today it's a 454 bowtie 10051107 casting number and it is a hyd. roller, is there any other way to find out what this cam is ?????????? Thanks
What part of my answer didn't you like?
Oh I liked all of it
Use your dial caliper to determine lift. Measure across the heel/nose. Write it down. Measure across the ramps. Write it under the other figure. Subtract. This is cam lift. Multiply times rocker arm ratio to find valve lift. Intake lift will be different from exhaust lift.
Do you have a degree wheel and a dial indicator? If you're gonna fiddle around with motors, these are a "must have". Here's the best type of dial indicator to use, Starrett #25-441J.... http://cgi.ebay.com/ebaymotors/Starr...motiveQ5fTools Here's the magnetic base to hold the dial indicator..... http://www.transcat.com/Catalog/prod...temnum=85235PD Here's your degree wheel.....http://cgi.ebay.com/ebaymotors/NEW-M...1%7C240%3A1318 Last edited by techinspector1; 12-23-2008 at 08:18 PM. |
| Anybody dealt with this guy on ebay? Or through Dirttrackthunder.com? | killerformula | Hotrodders' Lounge | 20 | 08-31-2008 05:12 PM |
| What cam specs work well with centrifugal Superchargers? | hotrodf1 | Engine | 2 | 09-22-2007 04:21 PM |
| What cam to go with Hyd. or solid (flat tappet BBC) | Bumpstick | Engine | 2 | 05-02-2005 08:26 PM |
| 305 cam carb manifold | stickshift | Engine | 6 | 04-12-2005 03:46 PM |
| BBC Comp cam EX274H, | Impala5967 | Engine | 2 | 10-01-2003 08:53 AM |
