Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - BBC Cam Lobe Paranoia?
Old 06-19-2013, 01:41 PM
66GMC's Avatar
66GMC 66GMC is offline
Get in, sit down, hang on
Last journal entry: Cab Removal
Originally Posted by 123pugsy View Post
Maybe it's my eyes, but that's the driest engine I've ever seen. Can't be good on start up.
Yes, it's dry. It hasn't run for about 2 years.
IF these lifters pass inspection, they will be getting the lifter lube treatment, fresh oil and NAPA Gold filter, and the oil pump will be primed again to the point of oil returning to the intake valley before this thing gets fired up again.
As to the coolant issue, I plan to fill it with water and warm it up ... then add a can of rad flush ... run it some more. Flush it with a flush tee and garden hose until it comes out clear, then drain and refill with fresh 50/50 premixed antifreeze.
In other words ... spare no expense and err on the side of caution!
I talked to my ex-boss this morning and he has agreed to come have a look.
