BBC cam question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2009, 08:03 PM
inquiring_mind2's Avatar
a shade tree mechanic
BBC cam question
I have a 60 over 427 with 14 to 1, closed,chambered heads( 290's), 6.135 rod length I would like to know what cam would work with this set up?? I am going to be using it for mud boggs. I would like to use a solid or roller cam. I also am using 1.7 roller rockers. any help would be greatly appreciated
Old 04-05-2009, 08:18 PM
i assume you will be spinning motor pretty fast so you will need a cam designed for good high rpm . i would personally use a solid roller cam over a hydraulic roller due to issues with high rpm valve float .you will need valve springs that are designed for the high spring pressures associated with a solid roller cam .you will need an intake manifold and carburetor that will supply the extra air and fuel needs that the larger cam requires . header size also needs considered .
CAM Question brad1 Hotrodding Basics 6 02-20-2009 12:19 PM
Comp cam change gear Question solidaxel Engine 9 08-27-2006 09:13 AM
Cam question 78 monte Engine 4 07-12-2006 09:26 AM
350 cam question Camaro1980 Engine 6 07-24-2005 06:35 AM
BBC cam troubles 2wld4u Engine 6 06-18-2003 03:21 PM
