Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - BBC crank identification help
Old 10-08-2012, 03:15 PM
1932bantam 1932bantam is offline
yes the thickness of third counterweight. 396 has a lighter rotating assembly if it is a 396 crank and making a 427 using 454 block probably should have everything balanced for longevity. you can't mistake steel crank. it has a wide parting line. just put a 3/4 end wrench on it it will either fit or not
