Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - BBC crank identification help
  #16 (permalink)
Old 07-24-2013, 08:35 PM
1986c10's Avatar
1986c10 1986c10 is offline
Oh wow, those cheap scat 9000 cranks are pretty solid. Im going to look into a kit with one if I can sell what I have. Will the 432 rotating assembly work for what I have though? All I have so far is the rotating assembly block and heads
It will go in a 2wd shortbed chevy street/strip
454 block .030" over
427 crank making 432"
781 heads 2.19/1.88 118cc chamber
Hydraulic roller cam im thinking something in the .600" lift range to take advantage of the head flow
Dual plane intake
th400 that will be built and whatever recommended stall converter
Rear gears will be decided at the same time
The main issue i see is very low compression, 9.07:1 with the 16.5cc pistons I have. I dont think that would make a good combo. I wanna make around 550hp for whatever thats worth
