BBC Dipstick info needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-03-2010, 07:16 AM
My 402 needs a new Dipstick and I need to know if a mark v Dipstick will work in a mark iv oil pan. I really don't want to use a china made chrome Dipstick. I really want a new gm one. My original one won't stay sealed in the pan and the tab is broke off were it bolts to the head, so anytime it goes over 4000rpm it starts to leak oil all over the header. If anyone can help that would be great.
Old 12-03-2010, 09:21 AM
sqzbox's Avatar
My pipes are my music
I had a problem like that on my small block. The dipstick would flop all around and when I wanted to check the oil the whole tube would want to come out.
I fabricated an L shaped bracket from a piece of 16 gauge steel with a hole in one end and bolted it to the valve cover using the cover bolt and secured the bracket to the dipstick tube with a fuel line hose clamp. it don't move anymore. It's not a show off engine but it did the trick.
Head info needed gilby246 Engine 2 10-08-2006 10:12 AM
87 s10 2.8 v6 to 3.4 v6 crate engine swap info needed 87sdime4x4 Engine 1 07-23-2006 08:15 PM
Machining Info. Needed GoneNova/406 Engine 10 06-22-2006 09:22 PM
T-5 trans info needed junkyardjeff Transmission - Rearend 1 08-14-2004 12:31 AM
1983 Chevy 3 Speed Clutch/flywheel info needed TurboS10 Transmission - Rearend 2 06-07-2004 05:57 AM
