BBC engine build ??????????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-23-2007, 07:52 AM
Whats up Hotrodders? I have a 68 BBC I have a stock crank with stock pistons. What would be a good hydraulic Roller camshaft to use. And also could i use my stock connecting rods and use a 10:5 dome piston. Your knowledge would very appreciated.
Old 08-23-2007, 01:50 PM
A 68 block will not accept the factory roller set up, that puts you into the rather expensive aftermarket.
Nothing short of race or airplane gas or methanol will accept 10.5 compression, this isn't practical, nor really even possible, to do on a street engine without aluminum heads.
Bogie
Old 08-23-2007, 02:10 PM
Guy Hiltz's Avatar
First we need more info,is this a 396 or 427 ? What heads ? What intake ? What do you plan on doing with it ? Street or strip ?? With the proper camshaft selection you can go as high as 10.5:1 and use pump gas,although it would be more practical to go with 10 or less,or as stated use aluminum heads.What kind of vehicle is this going in ?? With todays motor oils lacking important additives it is easier to acheive proper break in with roller cams,there have been lots of cam lobes going flat lately.Trans & gearing are also important in cam selection.
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Build 454 BBC for street blower 66GMC Engine 3 03-15-2006 01:02 PM
How can I build a 454 "POWER" Engine? stevecollins Engine 3 08-07-2004 07:55 PM
509 BBC 69 camaro, its all about the engine baby! Quarter mile killer Hotrodding Basics 12 10-28-2003 01:40 PM
509 BBC 69 camaro, its all about the engine, baby! Quarter mile killer Engine 10 10-25-2003 10:26 PM
