BBC flexplate - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-10-2010, 05:50 PM
BBC flexplate
alright i have a mid 80's 454 BBC with a scat crank...motor is 468....it has been balanced and all that, but i am currently running a 4 speed. i want to change over to a turbo 400 auto ...with the aftermarket crank is it still externally balanced?...and will it effect the rotating assembly since it wasn't balanced with it?....it is in a 86 chevy truck .....should i go with a heavier or stock weight flexplate.....thanks in advance
Old 10-10-2010, 05:53 PM
BOBCRMAN@aol.com's Avatar
Scat cranks are available in internal or external balance. To be safe, send your new heavy duty flexplate along with stick flywheel yo balance shop and tell em "match er up". Simple stuff.
Old 10-11-2010, 06:33 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If the the damper is externally balanced, you need an external balanced flexplate (one w/a weight welded on to it). If the damper is neutral balanced (aka internally balanced), you need a neutral balanced flexplate.
The external balanced damper- if OEM- looks like:
454 BALANCER
Notice the 454 balancer's counterweight is located inside of the hub, unlike a 400 SBC, that has the outer ring scalloped:
400 SBC BALANCER
You can tell if the flywheel has been set up as an externally balanced unit just by inspecting it.
There is a chance the flywheel was drilled as part of the rotating assembly balancing operation, so it might not be a bad idea to have the flywheel and flexplate checked to see that the flywheel hasn't been altered.
If it HAS, as was already said, the flexplate needs to be matched to it. Hopefully that is not the case, otherwise you have to do this every time you change the flexplate/flywheel.
But most times, the flexplate or flywheel and balancer are left balanced "stock" to avoid such problems.
Old 10-12-2010, 05:30 PM
thanks for the info guys
bbc flexplate question yevgenievich Engine 1 05-07-2009 08:24 PM
bbc 454 flexplate and clutch set up? dman16 Engine 7 03-15-2009 01:38 PM
72 pontiac flexplate powerrodsmike Engine 2 08-07-2005 12:47 PM
Ford Flexplate spacing k2mooch Transmission - Rearend 9 01-05-2004 02:51 PM
Small Block Chevy 400 flexplate install novajohnb Engine 2 10-31-2002 03:53 PM
