BBC Forged vs. cast pistons? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2010, 10:12 PM
My father is putting together a mild 454 for his 4x4 truck. Two bolt main stock cast crank, scat 7/16 forged rods 9:1 compression idle-5,000 cam. No supercharger or nitrous, the forged pistons are about 200 more than the cast. This truck will be daily driven, what would be the best piston? cast, hyper or forged? Just don't wanna be penny wise and dollar foolish. Thanks.
Old 10-26-2010, 10:18 PM
ericnova72's Avatar
More for Less Racer
Forged would be overkill. Great place for the use of Hypers, but plain cast would last just as well with that rpm limit.
Old 10-26-2010, 11:14 PM
ratpackin's Avatar
Last journal entry: old setup pic-
I think the cast will work great and last a long time with that engine.
This part I'm getting second hand, but someone had told me forged pistons can introduce more noise/slop during warm-up because of the different expansion rates between the forged pistons and the cast block. -Anyone confirm this? -or was he just talkin' to hear himself?
Old 10-27-2010, 01:13 AM
ericnova72's Avatar
More for Less Racer
Correct, but not entirely, it is not the difference between cast iron and forged aluminum, but the difference between cast aluminum and forged aluminum. Block expands the same for both. Forged pistons will have a looser fit in the bore until they warm up because the forged piston expands more than cast, so it has to be fit looser at room temp to allow for this expansion. May also have more blow-by and slightly more oil consumption when cold for the same reason.
Old 10-27-2010, 01:58 PM
Thanks, cast sounds like it would be the right choice.
WHY use hypereutectic pistons? Or forged?.... 54Guy Hotrodding Basics 37 11-24-2010 08:11 PM
4032 vs 2618 pistons for 540 bbc Biscuit6447 Engine 2 03-21-2010 11:19 PM
3rd 406 build attempt, hows this sound? klr650 Engine 25 11-24-2008 12:22 PM
forged pistons flipcat165 Engine 1 09-08-2006 12:05 PM
pistons hypo vs. forged 409guy Engine 2 05-17-2002 11:17 PM
