BBC front accessory drive...serpentine belt??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2013, 09:08 AM
Hey guys, just picked up a 72 Chevy C-10, 402BBC. I would like to convert over to a serpentine belt setup, but would like to go budget route, ie junkyard shopping.
I am not familiar with the BBC stuff, but know that the bellhousing patterns are the same as the SBC stuff , but whatg about the front of the motor? Will say a 95 TBI 350 front accessory drive work on my 402"?
The power steering/alt bracket? Tensioner assembly? What about the water pump?
Any tips/info greatly appreciated.
Old 02-09-2013, 09:26 AM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
You can use everything from a 93ish Chevy pick-up or S-10 with some adaptor brackets avai;label from KWIK performance.
Let me snoop around the pc a bit and see if I can find pics of the system on my 59.
Old 02-09-2013, 09:32 AM
Bryan59EC's Avatar
here are a few
PM me with your E-mail and I will send a word document with more info and phone number.
hmmm
only one pic shows up???
Old 02-09-2013, 04:21 PM
All of the pics shows up, thanks a ton. That is what I am talking about! I haven't been a fan of multiple belts, and pry bar applying tension for decades, and this new truck is no different. Belt's slipping/squealing, nothing more irritating when trying to snap the throttle and you get belt squeal instead!
Email coming..
Old 02-09-2013, 11:16 PM
big block serpentine drive
If you are in need of a complete set with an A/C delete pulley I may be able to help you out
Old 02-10-2013, 07:49 AM
Also, since you are saying 93ish....than that should be basically 88-95 than, if memory serves correctly as being the same set up, right?
88 would've been first year of TBI, and the serpentine, and 95 would've been last year. 96 going over to Vortec, and I know the brackets and accessories changed up some.
Old 02-10-2013, 09:15 AM
the set up I have is from a 89 chevy truck. It must use a long Reverse rotation water pump I have the complete set up, including a.i.r. pump, alt, p/s pump,have a photo if you like.
Old 02-10-2013, 09:48 AM
Banned
g.m. performance parts sells a complete kit with w/p alt, etc..
Old 02-11-2013, 06:59 AM
Bryan59EC's Avatar
PeePaw,
You asked in the e--mail about alternators.
You will need to use a CS130 or a CS130D, The earlier GM alternators will not fit in the brackets.
You can use the later setup if you like (95+) where the AC compressor is on the driver side, but I do not know if there is an AC delete bracket and pulley available.
93 ish brackets do not have a mounting for the smog pump the earlier trucks had,
and they look better as well.
You will have to use a power steering pump designed for the brackets, just change the fitting in the back to use your existing hoses.
Old 03-23-2013, 07:30 AM
OK guys, picked up the brackets finally. Now need to get the adapter plates from KWIK performance. Can't get rid of this multiple belt setup soon enough!!!!
Thanks for all the help/tips/pics/emails/links.
Oh, to the person that kept saying he had something available...sorry, but no offense...I saw that you only had 11 posts, and that was that.
BBC serpentine drive kits TimoFinn Engine 18 01-29-2011 08:54 AM
going retro from serpentine belt system back to v-belt can i swap out the reverse ro motorhead1945 Engine 5 06-25-2007 06:56 PM
Accessory drive belt sys? daoldbuick Engine 4 06-18-2006 09:24 AM
Serpentine Belt drive on a 283? csangster Engine 10 10-07-2004 09:00 AM
Serpentine belt drive for 350 Wheels427 Engine 20 05-14-2003 02:23 PM
