BBC Gear Drive or Chain - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-14-2008, 01:17 PM
What are the pro/cons on timing gear drive vs chain?
Is it true that the gear drive whines like a blower belt
sound? What keeps the gear drive from wondering? Is gear
drive better for longer life?
Thanks
Old 11-14-2008, 07:07 PM
DeathRattle's Avatar
Some Punk Kid
Use what you want...only difference I have seen between the two is cost. I have have used gear drives and chains, havent had the chance of using a belt system yet.
Noisy gear drives can become annoying...I'd suggest the quieter variety if you want to run a gear drive.
Old 11-14-2008, 08:47 PM
how many miles you expect out of it ?
them guys using the good stuff also tear down more often and inspect all .
Old 11-14-2008, 09:37 PM
WDCreech's Avatar
Grumpy Old Goat Herder
I speak from experience. A gear drive, without a blower belt to dampen harmonics, will eat valve springs in a solid lifter engine. With hydraulic lifters, the springs don't seem to expire so quickly. If you don't want to shell out the big bucks, for belt drive, go with the premium Roll Master chain, made in Australia. They, just, don't seem to stretch!
Old 11-14-2008, 11:54 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Amen to that. Crazy harmonics get transferred.
Belts are great, but they don't give you any warning before they break. When they break, the pistons hit the valves and you basically run the risk of turning your engine into recyclable scrap. They absorb crank harmonics beautifully, but unless you're racing with frequent belt inspection/changes, its a little risky on the street.
Gears last a long time, and might make an extra 1/2 hp, but at the risk of severe valvetrain harmonics. Its a hard gear drive. The crankshaft is constantly being hit with the force of a sledgehammer thousands of times per minute. I don't want a direct hard connection to my valvetrain and distributor unless its worth it for that extra couple ponies.
Chains are bulletproof, proven, cheap, and quiet. They also tend to give you about a year of warning before they break. The engine will run like crap, ignition will be all over the board, and the chain will hit the timing cover sounding like a coffee can with a couple bolts swirling around. If you break a timing chain it means you ignored about 10 months of obvious warning signs
I use Cloyes true double roller sets in almost everything I build. I have 126k miles on one right now and its still trucking along
700r speedo drive gear fleetsidelarry Transmission - Rearend 7 11-02-2007 07:07 AM
Gear Drive Pro's, Con's & Recomendations Willys473 Engine 21 04-16-2006 03:20 PM
BBC cam gear problem 454C10 Engine 4 12-14-2004 02:07 PM
Erson Gear Drive Woes blndweasel Engine 9 07-14-2004 09:53 AM
the best engine parts, chain vs. gear, engine combos jollygiant_57 Engine 6 05-01-2002 09:34 AM
