BBC gen 6 roller cam! - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-04-2008, 02:35 AM
Does anyone out there know what the differences are between the big block Chevrolet Gen 6 roller cam specs and will it work in a Gen 4 Block. Will a GM billet steel generation 6 roller cam /timing chain work in a gen 4 block if I use solid roller lifters, (as the gen 4 block does not have any way to secure the lifter retaining tray for the factory hydraulic roller lifters). ? Are the cam journal diameters the same? I am not very familiar with late model gen 6 BBC's. Any info would be appreciated. Thanks!
Old 01-04-2008, 08:13 AM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
The Gen VI uses a stepped-nose Cam with a retainer to hold it in the Block, along with a retainer boss-I am not aware of any conversion kits to install one in a Gen V Block, so I would say no, it will not work-
roller cam retro fit DARIN ALLMAN Engine 14 12-17-2007 05:29 PM
SBC roller cam selection 307malibu Engine 5 12-15-2007 10:53 AM
Roller Lifters - standard cam ckucia Engine 27 01-27-2006 02:05 PM
Anything special to put roller cam in 400 block? sb72elcamino350 Engine 1 04-10-2004 12:12 AM
Roller Cam Help!!! Vsanthos Engine 13 10-31-2002 05:29 PM
