BBC with glide ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2010, 01:19 PM
truckboy61's Avatar
BBC with glide ?
I just picked up a glide I'm going to put in my 61 c10 (4500 lb) got a 454 and 411 gears what upgrade are required and stall for street stripe ?
Old 03-04-2010, 02:40 PM
need to know about the engine, cam, compression, carb, headers?
Old 03-04-2010, 03:01 PM
truckboy61's Avatar
454 .030 , mild cam comp cam, closed chambered heads # 206 from 396 , Holley 780 DP , shorty headers
Old 03-04-2010, 04:45 PM
ericnova72's Avatar
More for Less Racer
With a Glide you are going to want 700-1000 rpm more stall than you would with a TH350 or TH400 due to the fact that you have less multiplication with the low gear in the Glide. Looking at your numbers I would say 3000 stall or a little more.
Why the glide instead of a three speed automatic?? A Glide only really shines with really high stalls and really light vehicles or really high powered engines, none of which is your situation.
Old 03-04-2010, 05:29 PM
truckboy61's Avatar
I already have the glide just trying to use what I got
Old 03-04-2010, 05:48 PM
You would be way ahead ... by changing over to a Turbo 350 or better yet a Turbo 400 IMHO. The Powerglide only has a 1.76 ( or a 1.82 ) first gear ratio. The Turbo 350 has a 2.52 and the Turbo 400 has a 2.48.
Way better suited to a heavier vehicle ... for getting it rolling. Either the Turbo 350 or the Turbo 400 will make FEEL LIKE ... the truck as another 50 to 75 horsepower ...
Old 03-04-2010, 06:06 PM
truckboy61's Avatar
Using a 3000 stall is that going to be practical on the street ?
Old 03-04-2010, 06:19 PM
ericnova72's Avatar
More for Less Racer
Myself and friends are currently running 4500 stalls on the street. all you need is a big enough fluid cooler, mine is the "stacked plate type", looks like a heater core, 8-1/2" x 11" x 1-1/2" thick.
Lots of BS stall myths about what can be run on the street.
Old 03-04-2010, 08:01 PM
truckboy61's Avatar
Sweet thanks for the info are there any negative draw backs?
Old 03-04-2010, 10:27 PM
ericnova72's Avatar
More for Less Racer
Gas mileage , every 10,000 miles trans fluid changes as the fluid takes a beating.
Old 03-04-2010, 10:56 PM
truckboy61's Avatar
It's a aluminum glide what upgrades do you suggest ? Would a shift kit be useful?
Old 03-05-2010, 02:46 AM
ericnova72's Avatar
More for Less Racer
Definately a steel clutch hub at your weight and engine size(torque vs weight ), then if you have the money a hardened input shaft. The stock input will survive if you don't hook it up hard, like with slicks. The rest is basic rebuild stuff.
Old 03-05-2010, 09:36 PM
junior stocker's Avatar
With a BBC, I would run an aftermarket input shaft. Every Powerglide needs a steel direct hub, unless it's behind a stock engine. I don't think most people really realize how thin and fragile the stock cast hubs lookm, and really are. At least a 5 pack direct clutch; easily done with stock pistons. Don't use the wavy cushion in the direct; use the reverse conical spring in a streeter, toss it with a trans-brake. The manditory "shift kit", to get higher line pressures. A good shifter to lock neutral/reverse out. And a decent sized cooler. But, if it were me, and since this is a truck, I'd use a TH400; sell the glide to a bracket racer, you'll be much happier. Butch/junior stocker.
Old 03-05-2010, 11:10 PM
truckboy61's Avatar
I also want to take this old truck to the track for some fun, even if it's slower then most ! What's the better of the 2 the glide or 400 ?
Old 03-05-2010, 11:24 PM
ericnova72's Avatar
More for Less Racer
You are 1600+ lbs too heavy to get good results(race or street) with a Glide, the Th-400 is a much better choice.
BBC vs SBC mount locations & dimensions? y5e06 Hotrodding Basics 7 11-17-2009 11:10 AM
bbc what gears to run.? chevelle4542speed Engine 5 12-07-2006 05:47 PM
96 to 00 BBC Question Mustangsaly Engine 6 02-20-2006 07:03 PM
BBC Big Block Questions Mustangsaly Engine 6 01-21-2006 06:59 PM
BOP Glide help olsixrod Transmission - Rearend 3 01-14-2004 07:27 PM
