-   -   Bbc got a knock need advice (http://www.hotrodders.com/forum/bbc-got-knock-need-advice-224668.html)
jumbo2 10-04-2012 01:48 PM
1 Attachment(s)
I have a 81 chev short box bbc well done , I was out last night crusing around and I stoped and hit it , 3500,4000,4500,5000,5250 tic tic tic so i let off , I was sure it was a bad roller rocker that came outa adjustment so I turn and head home and off the gas/idle/part throttle nothing but under load or above 3000 it rattles and the more gas the louder it rattles , come home pull both valve covers hot and start shaking rockers , every one seems tight so i fire it up covers off and hear nothing , rev it up and knock knock knoc aorund 2500 rpm . my guess is a rod bearing so i dont want to run it much more but i took a video.
my engine is
block 14015445
heads 336781 with scorpion 1.7 roller rockers and arp bolts
intake edelbrock air gap
carb demon 825
Ignition msd digital 6 /pro billet dizzy/blaster ss coil
ceramic coated hooker headers long tube 3 inch mandrel exhaust
If i rebuild I would want to build for the nos and use a roller cam and all existing parts but of course im on a budget , please help
th400 3500 stall and a brake / 9 inch 3:73 31/18.5/15 rear tires
150 shot of nos never used
jumbo2 10-04-2012 02:05 PM
I can rebuild what i have with arp rod and crank bolts and change pistons to get the 10-1 i need or change the crank for more cubes , truck is a toy but I want to street drive it and track it as well in the summer , does 500hp seem outa reach for this ? Is a 150 shot going to blow it up? there seem to be some cheap rotating assemblies out there with crank rods and pistons but im lost as what to do
