Bbc got a knock need advice - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-04-2012, 01:48 PM
I have a 81 chev short box bbc well done , I was out last night crusing around and I stoped and hit it , 3500,4000,4500,5000,5250 tic tic tic so i let off , I was sure it was a bad roller rocker that came outa adjustment so I turn and head home and off the gas/idle/part throttle nothing but under load or above 3000 it rattles and the more gas the louder it rattles , come home pull both valve covers hot and start shaking rockers , every one seems tight so i fire it up covers off and hear nothing , rev it up and knock knock knoc aorund 2500 rpm . my guess is a rod bearing so i dont want to run it much more but i took a video.
my engine is
block 14015445
heads 336781 with scorpion 1.7 roller rockers and arp bolts
intake edelbrock air gap
carb demon 825
Ignition msd digital 6 /pro billet dizzy/blaster ss coil
ceramic coated hooker headers long tube 3 inch mandrel exhaust
If i rebuild I would want to build for the nos and use a roller cam and all existing parts but of course im on a budget , please help
th400 3500 stall and a brake / 9 inch 3:73 31/18.5/15 rear tires
150 shot of nos never used
Old 10-04-2012, 02:05 PM
I can rebuild what i have with arp rod and crank bolts and change pistons to get the 10-1 i need or change the crank for more cubes , truck is a toy but I want to street drive it and track it as well in the summer , does 500hp seem outa reach for this ? Is a 150 shot going to blow it up? there seem to be some cheap rotating assemblies out there with crank rods and pistons but im lost as what to do
Need advice on 468 bbc quicksilver67 Hotrodding Basics 5 03-08-2011 06:37 PM
Engine knock diagnosis advice... Tyroma Engine 4 09-04-2009 06:00 PM
Bbc engine advice jackyandjoe Hotrodding Basics 6 06-15-2004 03:20 AM
Help!!! Knock, Knock, Knock coming from tranny 70bird Transmission - Rearend 1 05-06-2004 12:30 AM
Rod knock fix advice. M&M CUSTOM Engine 5 04-20-2003 05:48 PM
