BBC hard to start when hot and low oil pressure - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-22-2009, 04:39 PM
inquiring_mind2's Avatar
a shade tree mechanic
I have a 427 BBC in a jeep I use for mudd bogging. Last week I noticed it was hard to start I checked the timing. I have it at 38 total degrees. I also noticed the oil pressure would be 75 when I start it but when it gets about 160 - 180 it drops to 50 but doesn't go any lower than that. Today when I got ready to make my second run. I couldn't get it started. I turned the distributer clock wise and it started and it ran fine but the oil pressure was between 50 and 75. The oil pressure is fine until it gets warm like 160 or so. I am running havoline synthetic 20-50 racing oil. I have ran that type of oil all year oil and never had a problem with the oil pressure until last weekendI was told my gear on the end of the distributor could be worn??? I have no clue I am lost any help would be greatly appreciated
Old 08-22-2009, 05:19 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
That distributor gear would be the first thing I would check. I have seen them wear out quickly.
On a 481 BBC, the new intake manifold was so thick, it would pop out of the oil pump drive when I loosened the distributor to set the timing. It took out the gear that very same weekend of racing. I had to keep adjusting the timing to make the finals.
Old 08-22-2009, 08:21 PM
what would make the gear wear out like that?? Its only a couple of years old????
Old 08-22-2009, 09:25 PM
My 2 cents worth
Wiki Edits: 3
It's alignment into the camshaft gear. After any changes to the engine, such as camshafts, cylinder blocks, cylinder heads.......mechanical parts, or head gasket/ intake gasket thickness changes.......etc. Changes will be made to the depth of the distributor, to camshaft gear lobes.
We would refresh our engine in between the monthly racing events, and carry a spare engine(after that weekend), and a magneto, and a second MSD distributor, and new timing control box.
I also don't know how you 'winterize' your engine, if you back the valves off, or not. Weakening valve springs can allow the camshaft to be pushed farther forward. This in turn, will take out the distributor gear. I have seen this on SBC's, and BBC's.
We used 15 quarts of Kendall GT1 50W racing oil, and a quart of Morey's oil additive. Lubrication was never a problem.
Old 08-23-2009, 08:30 AM
the only time its hard to start is when the timing seems to be off. I have never had a problem starting it when it has been hot except the past couple of times. I readjusted the timing and it started fine so it has nothing to do with the starter.
Old 08-23-2009, 08:32 AM
on the timing gear will it be worn on the teeth or on the underneath where it goes over the oil pump shaft???
Old 08-23-2009, 08:37 AM
My 2 cents worth
Wiki Edits: 3
On the teeth.
Old 08-23-2009, 09:35 AM
ok thanks I will check it later this week
Old 08-24-2009, 10:13 AM
If I remember correctly you just upgraded to a solid roller cam. Did you put a bronze distributor gear on when you upgraded?
Old 08-24-2009, 11:15 AM
I have a solid hydraulic cam I wish I had a roller and I didn't replace the gear on the distributor
Old 08-24-2009, 11:34 AM
My bad I thought you had traded up already. I have no other useful input at this time.....lol
Old 08-24-2009, 12:03 PM
I do have one question...... Why is it only hard to start when it is hot if the gear is bad??????????????? When it is cold it starts right up and the oil doesn't fluctuate until its hot either
Old 08-24-2009, 07:19 PM
F-Bird 88
Whatever else is at fault, following the advice of FBird will enhance starting performance, especially when hot.
John
Old 08-24-2009, 11:10 PM
its not hard to turn over till it gets hot and I have to turn the distributor a little to the right and then it starts fine. the only reason its hard to start is because of the timing. You fix the timing and it starts great. I have an after market starter not a stock one. its for high compression motors. and I have checked every thing he said to check and there is not any problems with anything. Like I said you turn the distributor just a little and it fires right up
Old 08-24-2009, 11:16 PM
maybe check your distributer springs and weights they are in the bottom of your dist they may be stuck open and would cause some warm hard starts
Low oil pressure on SBC lg1969 Engine 30 05-30-2013 05:00 PM
Low oil pressure at hot idle oldguy829 Engine 12 02-08-2009 02:05 PM
Is it no good to have a High volume oil pump? Calderone Engine 17 01-31-2008 05:26 PM
Low oil pressure when hot and idling in gear. SixT2Deuce Engine 2 10-25-2006 11:40 AM
Low idle oil pressure chuckellison Engine 4 03-03-2003 07:20 AM
