BBC Head Casting CC's - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-07-2003, 08:29 PM
was just looking at a set of Heads casting # 6272292 Date D27 72 was wondering what the CC's are and if these heads would be good on a 454 Street motor. Also are they worth putting SS valves in..
thanks
Old 10-07-2003, 09:02 PM
DoubleVision's Avatar
only info I can find on these heads are
1971 402 / 454 open chamber, "peanut" port, 2.06 1.72 valves, 240 & 270 Horsepower LS3 /LS5
Old 10-08-2003, 06:41 PM
I am not sure if they are "peanut" ports they have the same size oval as my strip dominator intake. I have not found anything online that states they are "peanut" ports or there CC's. Is there a link that you have that gives them the peanut label?
thanks
Old 10-08-2003, 06:48 PM
BOBCRMAN@aol.com's Avatar
Actually the term peanut port is in refrence to the later truck intake port, it was about 3/4 the size of the passenger head port, for low and mid range power.
Old 10-08-2003, 06:52 PM
So you think that these are not "peanut" ports, but are they worth putting SS 2.19 1.88 valves in? and do you think that they would have the same CC'c as the '72 oval open chambers for the 404/454 of 113?
