BBC Head Machining - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-07-2011, 07:42 PM
BBC Head Machining
How much is this running you guys? I've been calling around for quotes for Valve seats from a std 781 out to 2.19/1.88, as well as valve guides installed, with and valve job. Cheapest I could find is $675 for both heads. I'm thinking this is a little steap?
One way or another this is still cheaper than buying aluminums!!
Old 02-07-2011, 07:53 PM
Is that including everything? I mean will they be ready to bolt on and go?Is this new valves and springs?
Old 02-07-2011, 08:03 PM
No, this isn't assembly, and I've purchased Manley 2.19/1.88 valves, and the valve guides, rockers, retainers, etc etc etc. This is just the machining that I believe I'm being charged an arm and a leg for! Putting the heads together isn't a problem, trying to save money and learn at the same time!
Old 02-07-2011, 09:13 PM
I would shop around.That price is a bit too steep.I had a set of BBs done last year had them machined for larger valves, new valves,new springs,guides . All of that set me back an even $600.
Old 02-07-2011, 09:18 PM
BOBCRMAN@aol.com's Avatar
I get $550.00 ==Bake&Blast. Magnaflux. Check for warp. Check guides. Shorten guides .400.. Cut for .530 seals. Serdi profile cut 2.19-1.88 seats to proper depth. Bowl hog area behind valves. Light blend, bowl/short side radius. Check for proper/available spring height on Intake and exhaust. No parts, not assembled.
If heads need surface cut up to .010. $55.00 each, if done during the above operations..
Old 02-07-2011, 11:08 PM
ericnova72's Avatar
More for Less Racer
It that price you are very close to the cost (about $100 more) to a set of the ProComp aluminum bare castings. You have all the parts, the bare castings are fully machined and only need a check out of valve job and guides by a machine shop and would be ready to assemble. Do some minor snading roll blending and cleanup if you want.
These are a decent casting.... it is the cheesy ProComp sourced valvetrain parts that are giving them a bad rep from folks that don't know any better, who buy them complete, bolt them on out-of-the-box and then complain when they have problems.
I would never put that much into old stock iron castings, it is just not worth it, eat bologna sandwiches and Ramen for a week and get new aluminum.
Old 02-09-2011, 06:52 PM
Just got the heads in today, best part is: They've already been ported!@!# They still need a LITTLE work, but I'm just going to touch it up with a die grinder, then get a polishing tip and go to town for a few days.
Not too bad for $220 shipped to my front door. Although, I still need to get my valves seats installed.. Any reputable places in the northern midwest (Minnisota, Wisconsin, Illinois)?
Old 02-03-2012, 01:36 PM
Gene Pearson ( Performance Concepts??? ) purchased one of my Serdi 100's and does great work. He is in Minneapolis. If you can't find him, PM me and I'll get you his number.
His shop is in his back yard and off the beaten path but he does awesome work.
Old 02-03-2012, 03:40 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
can you get those procomp castings in oval port?
or are they only square port?
Old 02-03-2012, 04:12 PM
Procomps are available in both port styles..
Old 02-03-2012, 04:14 PM
& matts38chev
thanks
because I have considered selling my 781s and getting a set of alums for the weight savings on the front end
cool factor also
Old 02-03-2012, 05:03 PM
stich626's Avatar
gearheadslife
Last journal entry: The TwoTonShu #10
Originally Posted by matts37chev
thanks
cool factor also
is it kool when the seats fall out..
Old 02-04-2012, 02:12 PM
The prices aren't outrageous. Depending on the part of the country, labor rates vary greatly. We charge $250 to enlarge the seats (with a "dead pilot" system using Serdi-style cutters), $100 to install the guides and $90 to resurface the pair. This is right in line with Bob's prices.
There are some options that can make a much better outcome for a little more money, like 11/32" stems/guides (valves are significantly lighter, and time has proven plenty tough). We install 1/2" OD bronze "fat guides" in the existing "knock outs", avoiding the added need for pressure testing when new guides are installed (exhaust side is exsposed to water).
ProComp heads, "bare", are NOT ready to install the parts and "go". No aftermarket head is really "ready to run". Unless you pay the "extra" for a pre-ported pair, they're usually a bit "scabby" and need at least some polishing. Usually, the imported heads need a bit of port work to make them perform nearly as well as say, Brodix or Dart. Even those, and E-heads, need some touch up when new. They all need upgraded valve grinds, too. Less expensive CNC-ported heads should be avoided as well, as the porting is suspect at best. "CNC" doesn't necessarily mean better, but it does mean once the ports were established, no improvements were made. We prefer to move ahead each time we do a pair.
Jim
cylinder head machining chevyguy13 Engine 3 10-21-2010 08:46 PM
general machining tolerance question (not just automotive based machining) lowROLLERchevy General Rodding Tech 9 12-28-2007 10:33 AM
Vortec head machining dougj169 Engine 3 10-16-2007 09:59 PM
Vortec head machining? bonzipenguins Engine 6 02-07-2007 12:04 PM
Machining a SBC 327 GIJoe4500 Engine 13 03-28-2006 07:11 PM
