BBC help - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2012, 10:07 PM
BBC help
I have been "creeping" around here alot lately and finally had a reason to join. I know I gotta "introduce" myself but I got a dilemma I need to find out an answer for fast. Can anyone tell me if the serpentine setup from a late 90s L29 454 will bolt to say a mid-late 70s 454 block? I know theres a ton of different generations of big blocks that were made so im not sure. I have a line on a complete belt setup for my car but dont wanna waste the money if it wont bolt to my older engine. Another quick question---will this truck belt setup fit in my car? The car is an 83 Monte SS. I have heard about the power steering hitting the steering box in cars but wasnt sure if it was this setup. This is what the setup looks like. Any input/advice is appreciated.
http://www.vortec454.com/index_files/image398.jpg
Old 08-18-2012, 05:40 AM
6426yy's Avatar
Checked around on a couple of other sites, I'm pretty sure they'll fit. I just put a gen V BBC in a guys truck and except for the one piece rear seal and the electric fuel pump they look identical. I'd love to have one of these, put one on my small block and love it!
Old 08-18-2012, 07:34 AM
BOBCRMAN@aol.com's Avatar
Also. The water pump will have to be replaced with serp compatible unit.
Old 08-18-2012, 01:53 PM
I put a BBC in a 1985 TransAm and used the truck serp belt setup. Had to cut the aluminum brackets and remove a section and weld them back together to clear a stock hood.
Old 08-18-2012, 06:40 PM
Thanks for the help guys. Can anyone tell me what problems I might run into dropping this in a G body?
BBC 049 Heads on 489-496 BBC with ISKY238/248 upper HYD roller cam kit Impala5967 Engine 3 11-14-2011 10:05 AM
N2O BBC V.S. 8-71 Blown BBC BottleBaby Engine 4 09-17-2010 01:48 PM
427 BBC or 598 BBC Geradmg Hotrodders' Lounge 1 05-02-2008 10:20 AM
BBC MK VI and BBC MK IV Heads Mustangsaly Engine 3 02-22-2008 08:57 PM
Will BBC headers fit any BBC heads? brian12c Engine 3 12-21-2005 12:38 AM
