Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - BBC hyd roller cam help
Old 10-14-2012, 12:26 PM
vinniekq2's Avatar
vinniekq2 vinniekq2 is online now
a 400 horse rat will make the 3500 pound truck run into the 11s. How did you decide on 500 hp?Buy a set of aluminum oval port heads if you want 500 hp.If you are racing,I would think awhile about camshafts. Are you looking for low or high rpm?If its 6k or lower,use the hydraulic roller.over 6k you should consider a solid cam.Big blocks need a few goodies to live at higher rpm s
