Originally Posted by vinniekq2
a 400 horse rat will make the 3500 pound truck run into the 11s. How did you decide on 500 hp?Buy a set of aluminum oval port heads if you want 500 hp.If you are racing,I would think awhile about camshafts. Are you looking for low or high rpm?If its 6k or lower,use the hydraulic roller.over 6k you should consider a solid cam.Big blocks need a few goodies to live at higher rpm s
If there are engine builds with peanut heads making over 500hp why would I swap my 781's out for $2000 aluminums ? without a ballanced engine over 6000 it wont live long so I will keep it under , 11.6 is the goal but dont plan only racing want to have a fun on the street as well
