Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - BBC hyd roller cam help
Old 10-14-2012, 12:49 PM
vinniekq2's Avatar
vinniekq2 vinniekq2 is online now
Unless you put your peanut heads on a flow bench,you really have no idea how many horses you can get from your engine.Porting your peanut heads is not money well spent.You mentioned using 3.73 gears,so you need lower rpm/torque engine.If you use a big cam to make high rpm horse power then your peanut heads will hold you back.
when you have flow numbers you can determine HP potential,,,
