Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - BBC hyd roller cam help
Old 10-14-2012, 12:56 PM
jumbo2 jumbo2 is offline
Originally Posted by vinniekq2 View Post
Unless you put your peanut heads on a flow bench,you really have no idea how many horses you can get from your engine.Porting your peanut heads is not money well spent.You mentioned using 3.73 gears,so you need lower rpm/torque engine.If you use a big cam to make high rpm horse power then your peanut heads will hold you back.
when you have flow numbers you can determine HP potential,,,
Maybe I didnt make things clear im not running peanut heads , If peanut heads can make 500hp why wouldn;t my 781's ? I have a good set of 781's and am capable of cleaning them up and even some port polish work
