Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - BBC hyd roller cam help
  #17 (permalink)
Old 10-14-2012, 01:36 PM
vinniekq2's Avatar
vinniekq2 vinniekq2 is online now
781s /peanut heads/vic junior aluminum,???w/e head you use,doesnt matter,flow test them to see what power you can make,,,,other wise you are guessing.The number 500 is just a number for bench racing.lots of lower h p cars,,,IE honda,, or other little 4 bangers go faster than BB chevys for a reason.
RPM/gear matching,,weight/hookup,,,are the things you need to consider.
again,my 80 Camaro ran 11.9 with stock LS-5 specs,using z-55 cam,830 holley,vic oval port,hooker street headers,turbo 400, 219/188s. If you want to go faster,improve on that package,better heads would make the biggest difference.
