Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - BBC hyd roller cam help
  #19 (permalink)
Old 10-14-2012, 06:43 PM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
Information I found is,The oval port heads flow 270 cfm in the intake side and 190 cfm on the exhaust side,Thats 70% on the exhaust side so a split pattern camshaft would be needed.If you really know your engines you could make 590 horse power or probably a lot less with all the right parts.Thats using a .600 lift cam.
the peanut ports flow 225/160 for the 156 heads and 235/150-165 for the 236 peanut heads,so 450 horse power maybe,,,not worth using in a performance car.
